Hello Everyone,
I've had two 36" x 48" fabBlock fixturing tables for about six months now. The tables are a great value and are extremely versatile. I use one for most of my general welding and fixturing; The other is a workstation that holds my vice, chop saw, and more tools are soon to come. Using Fusion 360, I have designed and fabricated a series of adaptors to mount the tools mentioned above.
I am creating this thread because I'm curious to hear about other's experiences with the tab and slot tables.
Here are some pictures of the mounts I've fabricated.
- IMG_2255.jpg (57.02 KiB) Viewed 2512 times
- IMG_2263.jpg (75.5 KiB) Viewed 2512 times
- IMG_2261.jpg (62.14 KiB) Viewed 2512 times
- IMG_2260.jpg (66.61 KiB) Viewed 2512 times
It was very affordable; $0. I buy a lot of product from the distributor so they "comp'ed" it. For mere mortals, I'm told it would have been $150/side.LtBadd wrote:Patience is a virtuecj737 wrote: Of course, I've spent a good deal of time Mag Drilling 864 holes in it... But I had mine Blanchard Ground on the top.
Very nice table, just curious what was the cost to Blanchard grind that?
Let me clarify: the grinding I had done was to remove Mill Scale, not to a thickness tolerance. So, if you require accuracy, Blanchard grinding will be more expensive. For a fab table in my world of 0.0 tolerance, a simple surface cleaning was all I required.Rudy Ray wrote:$150 a side?
i have 2 tales 48" x 60" x 1" that I would love to have ground. I was expecting something 5x that at least.
Trickiest part is to locate a shop with a grinder large enough. I had to call about 6 places before I found one. Actually, my metal supplier referred me, they shipped my top to the shop, then shipped it back to their shop, I picked it up from them. Saved me money. And I finally finished drilling holes last night. Tedious but it only cost me half a gallon of cutting fluid. And hours of sweeping
