moostang
    Tue Sep 18, 2018 10:28 am
I was wondering if anyone could tell me if the Vulcan TIG pedal will work with the Lincoln LE31MP. I realize a name brand one would probably be better quality, but for occasional home use it doesn’t seem to bad.
The ohm range and the wire plug would need to match.
moostang
I can’t find much information about either one of them. The one that is for my welder is K4361-1 and I can’t even find it on the Lincoln site. I’m going to go to harbor freight and compare the plugs but I don’t know what the ohms are for either one.
It should be listed in your manual. I would recommend a call to ck worldwide tech support. If you have your machine mn they can probably answer your questions about what your machine needs.
moostang
Okay thank you. I’ll do some more research.
