TraditionalToolworks
    Mon Dec 18, 2017 7:49 am
    San Jose / Kelseyville
For any of you with Chinese welders, you know how crappy the stinger and clamp are. My Everlast green weenie didn't have too bad of a clamp, but it paled in comparison to this 300 amp Lincoln. My green weenie is only 200 amps, but the Lincoln clamp only costs $6.25 on Amazon. I bought this about a year ago, but had to use my Chinese quick connect as the Lenco wouldn't fit properly. I prefer this style to the Tweco, but we all have our preferences. :roll:
Tonight I figured out what the problem was, as it turns out the Chinese Dinse 35 has a plastic bezel on it that protrudes out farther, preventing the Lenco from fitting in properly. I used some dykem to figure out the misfit, and to solve the problem I used a small homemade 1" belt sander to take off some of the handle front, allowing the Dinse connector to insert far enough to twist.
I've been using this clamp for a while, it's a great clamp. I used a hydraulic crimper to put a lug on the clamp end and some heat shrink around it. Glad to get the Lenco Dinse on there finally.
Everything is a problem on the green weenie, when I bought a CK torch I had to rotate the Dinse fitting for the torch so that the gas hose could plug in... :roll:
Lincoln 300 amp clamp
https://www.amazon.com/LINCOLN-ELECTRIC ... 326&sr=8-2
No 2 welding cable, when I bought this it was $1.15/ft, it's gone in the past year, I used 25', now it's $1.60/ft.
https://www.ebay.com/itm/WELDING-CABLE- ... 2749.l2649
Sanding on 1" homemade belt sander:
After sanding handle back:
after sanding the handle back
Lincoln 300 amp clamp:
Lincoln 300 amp ground clamp
Perfect fit with Lenco Dinse 35:
Perfect fit!
Perfect fit!
Collector of old Iron!
Alan
I’ve had to do do the same thing to my lenco connections so that they work on both my Lincoln 210MP. And mt ThermalArc 186.
Those lincoln ground clamps are a good value, I picked up a couple from Home Depot myself a while back.
Poland308 wrote:I use these.
That's the style I referred to as the Tweco style, I have tried one of those on a friends machine and wasn't crazy about them. Those do seem to be popular as an aftermarket clamp.
Alan
