ryanjames170
    Sun Sep 25, 2016 12:46 pm
    Wisconsin
what are the best rods "not limited to one rod" to keep on hand for most work?
Welder/Fitter
RM Fab & Products
Lincoln Invertec V300 pro
Miller 54D Wire Feeder
Miller 2E DC Welder Generator
Everlast Power IMIG 200
Everlast Power ARC 200ST
    Thu Mar 10, 2016 11:37 pm
    Wisconsin
What kind of work. If you are doing a lot of repair work on dirty metal-6011,6013 or clean metal more on the 7018 side. What do you want to weld and in what position would be beneficial to know.
    Sun Oct 27, 2013 10:57 pm
Farmwelding wrote:What kind of work. If you are doing a lot of repair work on dirty metal-6011,6013 or clean metal more on the 7018 side. What do you want to weld and in what position would be beneficial to know.
For your list of 6011, 6013, I'd be inclined to add 7014 - or replace 6013 with it and just have two types.
Sizes 3/32", 1/8", 5/32" as desired.
ryanjames170
    Wisconsin
general fab work,
Welder/Fitter
RM Fab & Products
    Wisconsin
For general fab work I'd recommend some 7014 or 7018 rods. They are common and are pretty good all around rods.
Farmwelding wrote:For general fab work I'd recommend some 7014 or 7018 rods. They are common and are pretty good all around rods.
+1
I'm a fan of 7014, and only $2 per pound here at the hardware store (L&M Fleet).
    Wed Jan 22, 2014 12:00 am
    Connecticut
There's nothing wrong with 7014, but honestly even without a rod oven, I prefer 7018. I just like the way it runs better than 7014. To me, if you have a stock of 6010 (or 6011 if you prefer), and 7018, you will cover 99% of your needs. You might keep some 6013 around for working on thinner stuff if you don't have a MIG or a torch to weld with. Pretty much all I have around any more is Lincoln 5P+ 6010 and Lincoln Excalibur 7018
PS I only pay $1.32/lb (delivered) for both 5P+ and excalibur rods by shopping on line at the Laredo TX Home Depot. Thanks Oscar! ;)
Multimatic 255
Louie's recipe for rod is about like mine. I have 6010 and 7018 for 90% . I have a little bit of 6013 I bought to try. And some SS 316 and 309 for specific projects.
I'm pretty easy to please. I keep 6011, 7014, and 7018 around in 3/32" and 1/8". I'll buy some Ni rod if I have some cast iron to weld, but I don't generally stock it.
Miller Bobcat 225
Tweco Fabricator 211i
AHP AlphaTIG 200x
Lincoln SP-135+
Hypertherm Powermax 30 Air
ProStar O/A torch
Louie1961 wrote:There's nothing wrong with 7014, but honestly even without a rod oven, I prefer 7018. I just like the way it runs better than 7014. To me, if you have a stock of 6010 (or 6011 if you prefer), and 7018, you will cover 99% of your needs. You might keep some 6013 around for working on thinner stuff if you don't have a MIG or a torch to weld with. Pretty much all I have around any more is Lincoln 5P+ 6010 and Lincoln Excalibur 7018
You're welcome :) if only they also carried 3/32" 5P+ and 7018 Excalibur. Now THAT would rock!
