Jonbrown1089
    Sat Nov 12, 2016 12:46 pm
    Connellsville PA
Unfortunately I got stuck with the task of patching a couple small holes and cracks in an old beat up Cat e70b bucket at work.
I've done a temporary patch early this spring just so we could finish a job and its come time to fix it somewhat right. Any body got any tips for me like should I just clean it up and burn a plate in with 6011 or should I use 7018? Does the patch need to be anything special or just a somewhat matches sized piece of carbon steel? The only working welder here at the moment it a Lincoin 225 Ac so that kinda limits me.
Alright guys and gals thanks in advance for any info you can share with me
Jon
"Ain't nothin to it but to do it"
Nothin runs like a Deere but the Cat that just ate it for lunch
    Thu Mar 10, 2016 11:37 pm
    Wisconsin
No expert but have you considered hard facing. If this isn't an option I'd clean it as much as possible and since you can only run AC I'd go with the 6011 and some 1/8" or 3/16"plate and weld it all around.
ryanjames170
    Sun Sep 25, 2016 12:46 pm
    Wisconsin
if it was me i would do the intial weld on the crack with 6011 and then go over it with some 7018-AC rods.
Welder/Fitter
RM Fab & Products
Lincoln Invertec V300 pro
Miller 54D Wire Feeder
Miller 2E DC Welder Generator
Everlast Power IMIG 200
Everlast Power ARC 200ST
Patch material should be determined by factors like if this is a wear spot or if it's a stress point. I would also grind it out good. If it's a crack then grind it all the way through. Weld it with 6010 or 6011 and then cap it and layer over it with 7018.
Boomer63
    Fri Sep 12, 2014 11:52 am
    Indiana near Chicago
Grind it, clean it. Spend a lot of time doing that. Get down to base metal. Make your root with your 6010, clean with a grinder - that might be the easiest way - top off with your 7018. On the reverse side, grind down to base metal, repeat the process. I know some of the other guys have suggested something like this, but that is my .02 cents!
Gary
    Fri May 27, 2016 11:00 am
    Atlanta, GA
If any of it is on the front of that bucket where it digs into the ground then you might wanna consider using hard facing rod. That stuff is ultra durable and made for tasks just like this. Just be aware that it will pop and ping and throw small pieces of metal at you for hours on end after you finish welding with it. It's not uncommon to have it still poping when you come back into work the next morning.
Raymond
Everlast PowerTIG 255EXT
    Wisconsin
Boomer63 wrote:Grind it, clean it. Spend a lot of time doing that. Get down to base metal. Make your root with your 6010, clean with a grinder - that might be the easiest way - top off with your 7018. On the reverse side, grind down to base metal, repeat the process. I know some of the other guys have suggested something like this, but that is my .02 cents!
Gary
I could agree with 6010, but with an AC only stick welder, 6011 probably the next best thing.
Jonbrown1089
    Connellsville PA
Thanks for all the tips and advice guys I'm getting the bucket cleaned up in the next evening or 2 then I'm going to try to borrow my buddies diesel powered dc welder for a weekend. If I can get it I'm going to hit it with some 6010 then 7018s. None of the cracks or holes I currently know of are on the work face of the bucket but if I find any I'll look into the hard facing rods. I plan on running a few sticks of 1/4 x3 plate the with of the bucket for wear pads and to try to reinforce the corners where the steels running thin
Tommy2069
    Sun Jun 05, 2016 10:03 am
most metals used on equipment are tempered steel so don't forget to preheat or you just might comeback the next day to see cracks.
