Qmccracken
    Thu Jan 26, 2017 11:23 pm
Howdy everyone, I'm new to this hole forum thing and notand em trying to get the hang of it. I'm a technically sound welder but lack the fundamentals. I work with a lot of 2 and 3/8" drill stem. I always used to run a wire welder on it but the outfit I work for now only has a small wire welder that can't handle the prologue use. So I em on the stick welder witch I em fine with but I em running in to issues. Such as what electrodes are best for this kind of pipe? I em also having issues with magnetized pipe. Sometimes everything welds great but sometimes I have a hard time getting a good weld to form, it's like the material won't be fuse together. Anyway if anyone has any advice or tips it would be much appreciated. Thank you.
Is this pipe for a drill on a drilling rig? If so what size and diamiter of pipe?
    Fri Apr 01, 2011 10:59 pm
    Australia; Victoria
7018ac or 6011, specifically designed for AC welding which will get rid of your issues with magnetised pipe.
