CE CLECKLER
    Mon Nov 09, 2015 2:45 am
I haven't fired up a stick yet, nor have i put one to the grinder, but i was wondering if there is a way to tell what a rod is by looks? It has a dark gray almost black flux, and the bare end is painted dark red. the packaging is a plastic bag, green and i'm sure used to be clear, and the only part you can read is safety info about fumes and rays. i will do some testing, but thought i might try the wealth of knowledge here too. thanks in advance.
Rods should be labeled on their exposed end indicating their spec. :?:
Some companies used to use a color dot system. I'll see if I can find a chart. I think one red dot is 6010.
The "almost black" flux and red color suggests 8010. Love those rods, if that's what you have.
CE CLECKLER
Poland308 wrote:http://www.shopfloortalk.com/forums/att ... 1319426182
Here's a partial list
i tried to grind a stick..very little sparks and very hard. looking at the chart im leaning toward a cr/ni rod...i took a couple pics but need to change computers to post them.
