It is currently Mon May 22, 2017 3:22 pm Advanced search
Dynasty 280dx running 7018 Rod
Postby axial2terminal » Tue Mar 07, 2017 7:21 pm
Hello All,
Looking for any suggestions for running 7018 rod on a Miller Dynasty 280dx.
Practicing for 1" 3g plate test, so far the welds are ok but not as good as what
we are getting with an Everlast Powerpro 205.
Right now my settings are:
- DCEP
- 115 amps
- Stick Stuck/Hot Start on
- Dig @ 60%
- Output - on
It just doesn't seem to be running as smooth as the Everlast (also an inverter machine), same
parameters set on that machine.
Any replies greatly appreciated.
Thanks!
axial2terminal
Re: Dynasty 280dx running 7018 Rod
Postby cj737 » Tue Mar 07, 2017 7:36 pm
I have an older 200DX, and I run 3/32 7018 at about 80amps, no DIG unless overhead or uphill. At 115amps, what diameter rod? Suspect 1/8, but asking to be sure.
Postby axial2terminal » Tue Mar 07, 2017 7:46 pm
Hey CJ,
1/8" rod
vertical uphill passes
rod about 90 degrees to workpiece
axial2terminal
Postby Oscar » Tue Mar 07, 2017 8:07 pm
From what I've read, Dig is more ideal @ 30% or less with 7018.
HTP Invertig 221 DV w/ Arctic Chill cooler DV.
Millermatic 211 Inverter w/ Spoolmate-150
Eastwood Versacut 40A Plasma cutter
Oscar
Postby PeteM » Tue Mar 07, 2017 9:25 pm
I agree. I only turn up the dig for running a root with 6010. For 1/8 7018 on that particular test I like to run it at 123-125 amps.
PeteM
Postby Olivero » Fri Mar 10, 2017 10:38 am
I run 1/8" 7018 at 120A, depending on the application but mostly I run with my Dig at 100 %
Olivero
Postby axial2terminal » Fri Mar 10, 2017 12:23 pm
So I called Miller to try and get some info about the machine and this particular process.
Apparently you don't need to swap the ground and stinger as you would on other machines
to get straight (DCEP) polarity, the machine automatically does this for you.
There is nothing in the manual which explains this.
The rod runs much better now, running some 1/8" Lincoln Excalibur and getting pretty good results.
Thanks all!
axial2terminal
Postby cj737 » Fri Mar 10, 2017 3:26 pm
axial2terminal wrote:So I called Miller to try and get some info about the machine and this particular process.
Thanks all!
Had you been swapping the work cables? That would explain a lot 8-)
Postby PeteM » Fri Mar 10, 2017 3:32 pm
I found it on page 33, process selection.
PeteM
Postby axial2terminal » Fri Mar 10, 2017 6:02 pm
Didn't think to look in the Maxstar 280 section for information on the DX....
Thanks for seeking that out partner!
axial2terminal
Next
