olek
    Sat Jun 03, 2017 4:07 pm
    France
Otto Nobedder wrote:A "stringer" lets you oscillate the thickness of the rod. For a 1/8" rod you can "weave" 1/8" and still call it a stringer.
Steve
Can you please tell me what mean the guy in that 7018 text from Lincoln where he state :
"When welding the second pass, use a weaving motion or stringer technique. If you opt to weave, think of the number 8 sideways and move from left to right. Also, pay close attention to the bead width when using the weaving technique. Try to keep it at ¾" or smaller for the maximum width overall after multiple passes. For the stringer motion, create the letter “I” and follow in a straight motion "
(That mean a stringer then another next to it ? It is not a "ladder" )
As I don't know the direction of the weld, I thought that for the 8 this is a normal 8 may be a little pinched that goes from left to right recovering itself (?)
Thanks if you have a little time for that. I do not get well the restart explanations, too (I do not understand what is particular in his description of restarts)
http://m.lincolnelectric.com/en-us/supp ... egory.aspx
Regards
Pianos , restorer and tuner
olek
    France
Farmwelding wrote:
PeteM wrote:Its person to person. Once you have a good bit of time on the metal, get comfortable with a good setting and get used to the actual motion- they're pretty much all the same. You can't get complacent (not that you would) and assume that the weld will make itself, but it does get easier.
Just don't get too into what you're listening to on the I pod and use the stinger to crash the cymbal. That makes a mess. :lol:
Yeah I hear you on that. I will rarely listen to music when I weld. Usually tig welding since it usual is a little quieter at least for DC. And I try to wear ear plugs to and even without ear plugs I don't need any more noise. Although it would be pretty funny to watch somebody do a nice cymbal crash.
And I know never to get to comfortable running something. That's when undercut, slag inclusions, and all the other fun stuff happens.
Farm weld, I may admit I have no idea of the type of training you did attend. Was in a welding school, a "camp" ?
(Just curious)
As I was stressing too much at the beginning I used to listen to music I like , could be salsa, reggae, rock, it helped me to move more supple. I stopped after a while and concentrated more on the sound of the weld and welder machine.
Regards
    Thu Mar 10, 2016 11:37 pm
    Wisconsin
Well next year I'll be a senior in high school but this last year and next year I got/get to take classes at my local tech school, but in this instance I was not taking an actual welding class the last semester because of a dumb pointless class...either way a welding instructor that teaches there came down with a box of 3/32" 7018s that were crap we found out but I saw him a week later and told him and he said to come up and he'd show me some stuff and then threw me into the fire...literally and figuratively. So it was a lucky shot that I happened to see him and he liked me and I can at least make it seem like I know what I'm talking about
This is an example of stringers.
olek
    France
Thanks, Farmwelding, you have been lucky I suppose it is normal sometime ;) best of luck for the next year .!
The stringer : no manipulation or very little there ? Is the upper weld 3 times the diameter of the rod.
No way to test those types with penetrating dye I suppose. ?
What 'tricks' are possible to repair or correct undercut ? Farmwelding seem to say something about...
Thank you
It's an odd picture angle. Those were welded with 3/32 7018 and the bead is about 1/4 wide.
olek
    France
Poland308 wrote:It's an odd picture angle. Those were welded with 3/32 7018 and the bead is about 1/4 wide.
I was not far it is almost 3 times no ?
Did you do that by dragging very slowly and straight around, or with a very small weaving ? That is about how much Amp ?
For the short arc I am at it from the start, I think I even had too short an arc with the 6013 sometime Wich make the puddle touch the rid then may be try to pass behind or make inclusions.
I prefer 7018 . Now is it possible to have a too short angle ? Is gas shield insufficient then ? Sorry for the many detailed questions , I weld "in my head ": before going real ;)
Yes you guessed close on the size, those were made with almost no manipulation. Mostly a drag angle but some changes to a 90 deg angle and then a push as I go around. I've only run about 10 lbs of 6013 but I noticed its possible to get slag inclusions. It's also possible to get that with 7018 but my experience with that is that it was from weaving too far or too fast. The gas shielding with stick happens right at the point that the flux burns off. It only creates a small pocket of gas hence the need to keep your manipulation small or weave at a slower rate. You can make wide weaves over 3/4 of an inch wide even with 3/32 rod you just need to weave slower.
olek
    France
Thanks Josh those are great details, they help a lot ;)
I was not expecting you could go 90 and even more to push while keeping the weld free of slag . You still touch the base l'étal when pushing ? (At 90 I guess no)
I will look at the puddle plus the gas shield together I think . You see the gas shield moving the surface of the puddle (7018) or is it only the metal "cooking" as we can see under with 6013 ?.
What your seeing is probably the slag as it mover across the puddle and starts to form. There's a little bit of an art to seeing the slag and yet seeing what the puddle looks like underneath that.
olek
    France
Poland308 wrote:What your seeing is probably the slag as it mover across the puddle and starts to form. There's a little bit of an art to seeing the slag and yet seeing what the puddle looks like underneath that.
I get it ! "A bit of an art ;)" I trust you ..
And
I was not expecting you could go 90 and even more to push while keeping the weld free of slag . You still touch the base metal when pushing ? (At 90 I guess no)
Maybe I don't touch when the rod angle is 90, I don't pay much attention to it. I'm focused on keeping the arc close while watching the puddle and trying to keep an eye on the edges.
olek
    France
Poland308 wrote:Maybe I don't touch when the rod angle is 90, I don't pay much attention to it. I'm focused on keeping the arc close while watching the puddle and trying to keep an eye on the edges.
Anyway, touching/dragging is something when there is no weld , after that the weld you touch tend to melt soon I understand that as you say the priority is to watch and control the puddle ( and seen if trouble occur with the edges at the same time, as you say this is quite of art - you did not say but I am sure you agree ;) )
When I made my exercice this afternoon touching the left and the right side made undercut for the left and not for the right, at some point ( I was weaving smiles)
Could it be that simply the right side had more metal under it so it accepted the 110A without trouble, while the less large left side I should have stay less long on this edge ?
I did not find it too easy to be certain I was oriented on the bissectrice of the angle but I tried to sit well in front, and balanced the whole arm so to keep the same position left and right, so I do not understand.
Plus I did see the undercut, but moving up for the next bead have to be done so quick I was short of reflexes ;)
Regards
Yes if you have differing thicknesses that will have an effect. You can aim your rod more towards the thicker side to compensate a little.
olek
    France
I am doing exercices on a cross shaped block.
Good results, nicer beads, more eveness, slag falling, better straightness, longer but tense arc.
Making again and again the same gesture is good at any point in beginners training I think. I did that yet 2 months ago, doing again show differences that is really helpful
Someone just told me it is unnecessary to make manipulations, that for better learning of reflexes gesture stringers where more useful.
He also tell me to enlarge the arc if I want a 2 electrode size puddle.
I think he may be right for the stringers, but enlarging the arc?
I was just capable lately of enlarging the arc a little and got better beads with 6013 ( I did weld with a buzz box the first month , and took the habit of a very short arc with it ).
But I use very small z to get to the size I want.
I thought that the inclination should allow to manage the puddle size if no z motion is used
What do you think ? MAya be thinner beads but perfection in regularity is first necessity before working out the Z motion ?
May be I should only wait more at the start so to have a larger puddle to move ?
Are you changing electrode inclination "on the go" eventually without noticing, to keep the puddle shape ?
Thanks for your thoughts.
I know theory do not make proper gesture training but at this point it helped me to analyze my beads. Hence all the questions.
olek
    France
I could enlarge the arc somehow.
Better heating visibly.
But still I needed small z motion to enlarge the puddle.
I am supposed to do stringers, are they 1.5 electrode side, about that ? ( the size of the puddle I had without manipulation may be simply I should slow..)
https://goo.gl/photos/F8ixQViQfZ3UFxAt7
No more undercut (but 120A, not 110)
Looks like your on the right track. But just need more practice. One note would be to take a wire wheel on a grinder to the previous passes after you nock off most of the slag. Looks like in a few picks you are getting holes and lack of fusion on the toes in a couple of small areas. Probably because there were still little bits of slag that you welded over.
