It is currently Thu Feb 22, 2018 4:37 pm Advanced search
metal recovery about 120%
Postby mkhoshzaman » Mon Jun 19, 2017 2:25 pm
does any body know about this sentence?
basic coated with about 120% recovery .
i saw this on electrode specification label .
mkhoshzaman
Re: metal recovery about 120%
Postby weldin mike 27 » Tue Jun 20, 2017 4:06 am
It means that there is some kind of metal powder (most usually iron) in the flux coating that adds to the weld. There for you get the core wire plus a bit more from the coating. This is usually found in rods like 7024 iron powder.
I hope this is what it means, otherwise it's another thing i'm wrong about.
weldin mike 27
Postby Poland308 » Tue Jun 20, 2017 6:45 pm
And 7018
Postby olek » Wed Jun 21, 2017 8:11 am
I have seen up to 180%, look at Lincoln or Esab catalogue, on some rod may be 7024 (?) (there are also rutile 180%)
++"iron powder" in the flux, does it mean iron really,(as cast iron) it turns to steel when cooked with the welding heat ?
Pianos , restorer and tuner
olek
