It is currently Sat Aug 19, 2017 8:51 am Advanced search
Best budget tool to cut and etch (and cut for usual work) ?
Postby olek » Sat Jul 29, 2017 7:57 am
I'd like to find a "not too expensive" cutting tool that make cut and etch easier
My main problem is dust so a collector would be ideal
ANd also minimize heat so it is easier to finish the surface for etching
It seem to be possible to use an electric metal saw, or large cutting disk (diamant ?)
What do you think ?
I can do the cutting outside indeed, but not always
Thanks
Pianos , restorer and tuner (technician)
Dedicated to learn stick welding since april
pro inverter PROGYS 200 FV PFC CEL+tig lift & end of gas regulation
olek
Re: Best budget tool to cut and etch (and cut for usual work
Postby Oscar » Sun Jul 30, 2017 10:48 am
Best bet is a cutting disk. Whether it be a large 14" abrasive saw, or a thin 1mm cutting disk on an angle grinder, you WILL have metal dust to deal with. Its just not something you do indoors. You still need a small polishing tool to get the fine scratches out to see the etch. Do you have an air compressor?
HTP Invertig 221 DV w/ Arctic Chill cooler DV.
Millermatic 211 Inverter w/ Spoolmate-150
Eastwood Versacut 40A Plasma cutter
Oscar
Postby olek » Sun Jul 30, 2017 10:59 am
Oscar wrote:Best bet is a cutting disk. Whether it be a large 14" abrasive saw, or a thin 1mm cutting disk on an angle grinder, you WILL have metal dust to deal with. Its just not something you do indoors. You still need a small polishing tool to get the fine scratches out to see the etch. Do you have an air compressor?
Thanks, yes I have air and enough for pneumatic tools. Used angle grinder with 60grit 3m disks to prep the surface) as seem to do Jody)
I have polishers, cotton wheels (not sisal but large cotton wheels, and smaller ones, felt disk too ) Menzerna pastes (wax) and other..
My question is really what will be the most interesting investment, assuming of course I plan to build a chariot, some gigs, a support for the piano panels and parts,...
Is there a possibility to extract dust at the cutting disk? (I have turbine for fumes extraction but it is strong enough to catch metal dust (flat wings)
The saw look nice but I suspect only the largest models, on stands are really worth.
Regards
olek
