It is currently Sun Oct 22, 2017 2:24 am Advanced search
Mini-Weld 130
Re: Mini-Weld 130
Postby Artie F. Emm » Thu Sep 21, 2017 4:02 pm
Welcome to the forum. I did a quick check but didn't find anything about make and model. Does it weld?
Dave
aka "RTFM"
Artie F. Emm
Re: Mini-Weld 130
Postby gabyh » Thu Sep 21, 2017 6:19 pm
it's seem like a inverter maybe produced in italy but i don't known who is EWS company/manufacture
gabyh
Re: Mini-Weld 130
Postby Artie F. Emm » Fri Sep 22, 2017 12:48 am
Agreed, an inverter with DC output based on the marks on the electrical plate.
How did you come to have it, and does it have cables with fittings to weld? One will be a ground clamp and the other holds the electrode.
Dave
aka "RTFM"
Artie F. Emm
Re: Mini-Weld 130
Postby gabyh » Fri Sep 22, 2017 5:39 am
another foto
http://www.tehnium-azi.ro/uploads/month ... 074758.jpg
http://www.tehnium-azi.ro/uploads/month ... 212631.jpg
http://www.tehnium-azi.ro/uploads/month ... 212653.jpg
use irfp 450 and mur diode/rectifier
what tipe of potentiometer i can use because i lost him ...original it's a potentiometer with hole in the midle..2.2ko
gabyh
Re: Mini-Weld 130
Postby Artie F. Emm » Fri Sep 22, 2017 7:30 am
Ok, sounds like your machine needs a potentiometer.
If you'll google "2.2k potentiometer" you can view images to see which one is closest to the one you remember- there are several with holes.
Good luck- let us know how it goes!
Dave
aka "RTFM"
Artie F. Emm
Re: Mini-Weld 130
Postby gabyh » Sun Sep 24, 2017 4:14 am
problem it's not potentiometer ...connection of potentiometer pins is problem ...on the pcb
gabyh
Re: Mini-Weld 130
Postby Otto Nobedder » Sun Sep 24, 2017 9:07 pm
gabyh wrote:problem it's not potentiometer ...connection of potentiometer pins is problem ...on the pcb
So, cold solder joint?
A common flaw. A simple re-melt with a fully hot and properly tinned 35W soldering iron should have you up and going.
Adding a tiny dab of some fine rosin-core solder is never a bad idea, as there may be oxides inside the failed joint.
Otto Nobedder
Re: Mini-Weld 130
Postby gabyh » Mon Sep 25, 2017 7:30 am
i repeat ..problem is ...i don't known which is the pinout on pcb for this potentiometer
gabyh
