It is currently Sun Jan 21, 2018 5:55 pm Advanced search
Stick welding fumes
Stick welding fumes
Postby JBeasty » Sat Nov 11, 2017 4:43 am
Hi, new to the forum. I've just started stick welding. Been practicing in my side yard (covered patio, open on the ends). When it's not windy, I get the fumes in the face. Tried an N95 mask, but I can still smell it. I've read about DIY fume extractors, but this seems kinda pointless outdoors. I have a box fan I could use to blow the smoke/fumes away from the immediate area. Any reason why this is a bad idea?
Thanks, JBeasty
JBeasty
Re: Stick welding fumes
Postby weldin mike 27 » Sat Nov 11, 2017 5:57 am
A fan to blow away stick welding smoke is a great idea. You'll see Jody do it in some of his videos.
weldin mike 27
Postby Poland308 » Sat Nov 11, 2017 9:48 am
I like to set up a fan so that it sucks the fumes away.
Postby JBeasty » Sat Nov 11, 2017 6:35 pm
Awesome guys! I'll try it both ways - suck and blow... Aw hell, you know what I mean.
JBeasty
Postby JBeasty » Sat Nov 11, 2017 11:23 pm
Just curious Josh, how close do you have to have the fan to your project to effectively pull the smoke away? I Imagine I could put it a good distance further away if I was using it to blow the smoke away, but I like the idea of using it to pull the smoke away, especially on a cold day. Guess I'll just have to test it out and see.
JBeasty
Postby Poland308 » Sat Nov 11, 2017 11:57 pm
Depends on the fan and how powerful it is.
Postby olek » Wed Nov 22, 2017 6:20 am
The big tube at the front is a silencer -It is a second hand turbine, originally used in a engraving machine to extract fumes
Pianos , restorer and tuner
olek
Postby JBeasty » Wed Nov 22, 2017 3:00 pm
Makes me wonder if using my shop-vac would be an option, provided I have enough hose.
JBeasty
Postby PeteM » Wed Nov 22, 2017 3:40 pm
JBeasty wrote:Makes me wonder if using my shop-vac would be an option, provided I have enough hose.
I've thought about doing that before. Having a switch by the end of the nozzle would be great too.
Realistically though, I just use a fan to draw the fumes like Poland suggested. Noise kind of gets on my nerves and I like to be relaxed when I weld.
PeteM
Postby olek » Wed Nov 22, 2017 3:51 pm
fumes get everywhere in the tubes and turbine, leaving some material that looks a little greasy.
I dont know how the vacuum filters will appreciate that , as they are intended for dry particles, dust, wood.
if the turbine is at risk, a venturi system may work well enough for fumes.
olek
Next
