It is currently Tue Jan 23, 2018 5:37 pm Advanced search
Stick welding fumes
Re: Stick welding fumes
Postby JBeasty » Thu Nov 23, 2017 3:50 am
Yeah, after thinking about it, the fan idea makes the most sense for me. Cheap, easy and relatively quiet. My shop-vac is so loud I wear ear plugs when I run it.
JBeasty
Postby olek » Thu Nov 23, 2017 4:30 am
JBeasty wrote:Yeah, after thinking about it, the fan idea makes the most sense for me. Cheap, easy and relatively quiet. My shop-vac is so loud I wear ear plugs when I run it.
Ideally, a turbine is outside.
As those are providing some aspiration à few meters of tubing can be envisaged without too much losses
It is not easy for me due to the walls, so my solution is to create a heavy box with isolation so the noise lower.
The silencer is also effective.
To help à fan, make it more efficient, some length of tubing front and back will help a lot, there are much turbulences around fans the aspiration zone and level is quite small in the end.
I use an "industrial" type in a door I added to the entry door, I could see how different the result is with the tubing (thin aluminium foil) front and back.
Suddenly my cell phone atmospheric pressure detector did notice something (I don't remind, 1-2bar I think), and the whole piece is not hermetic at all.
A few computation volume vs flow, may be useful.
If not too noisy those small units that are intended to be plug on a supple tubing, may do the job too (they are designed to create a good aspiration level unlike fans )
The formulas are easy to find, some on the turbine and fan makers, to choose a model depending of the use.
For a paint booth you look for 0.5m/sec air displacement.
Fumes rise so it may be different, I have a vertical flow (not very strong) and aspiration at floor level.
Pianos , restorer and tuner
olek
Postby Louie1961 » Thu Nov 23, 2017 11:16 am
Put the fan behind you, it will be much more effective. Also, if you line it up right, it will keep the fogging in your welding helmet to a minimum. stick welding is pretty immune to wind and drafts, so let it rip.
Hobart Handler 190
Syncrowave 250
Purox Metalmaster
Louie1961
Previous
