Hello guys! Im new to welding overall and this week were stick welding in school. I just wanted to gwt some feed back and some tips if possible! Thanks in advance were using 7018 rod! And will be vertical welding next week.
- 20191003_202901.jpg (82.92 KiB) Viewed 672 times
- 20191003_210307_HDR.jpg (75.25 KiB) Viewed 672 times
- 20191003_210322.jpg (75.2 KiB) Viewed 672 times
I see a case where the weld looks cold not so much long arc'ed. The toes of your weld are rolled under, not tapered in.
Bump your amps up 5 more and run some new beads. Your travel time looks fine, and for a new welder you're off to a very good start.
