WelderDan
    Sun Oct 27, 2019 1:50 am
    California
Is grounding to a table instead of the work peice advantagous?
    Fri Apr 01, 2011 10:59 pm
    Australia; Victoria
No, because if you get an interruption between the table and the job, such as mess or tooling, you'll end up with stray arc marks on your job where the ground path tries to jump the gap
Homemade
    Tue Sep 12, 2017 8:31 am
Especially with mig welding. Those keep spitting out wire regardless of ground.
tweake
    Mon Dec 18, 2017 4:53 am
    New Zealand
WelderDan wrote:Is grounding to a table instead of the work peice advantagous?
as mentioned above no. however you can use a third hand that has copper feet to connect to the work. that can provide better connection and reduce arc marks.
