fatelvis
    Mon Jan 11, 2010 11:08 pm
I was thinking of buying a Lincoln Invertec V275-S stick Welder, but using a generator to power it sometimes (230 volt). Is this a problem? Thanks-
    Fri Feb 12, 2010 10:48 am
    YOUNGSTOWN, OHIO
as long as the generator can handle the power draw of the welder you should not have a problem. Check the parameters of the welder and the generator carefully to make sure .
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
Hypertherm Powermax 85
Miller Digital Elite
JD2 Model 32 Bender
Oxy-Gas Torch outfit
Generac XP8000E Generator
