Drramore
    Tue Apr 28, 2020 7:19 am
If I want to weld a patch on to my very thin (1 mm) metal shed, and so use electrode negative so as not to blow through the sheets and to get a good weld, is there a risk that clamping the positive electrode to the shed, which is likely to be earthed simply due to contact with moist soil / deep metal pins, etc., will cause an electrical short.. at best tripping a switch, at worst causing an accident / fire?
Would someone opening the door to the shed be at risk of an electrical injury?
Thanks people :)
cwby
    Wed Nov 13, 2019 7:07 pm
NO. You will be good to go.
Agreed. In short, No, you will be fine, regardless of what polarity the clamp is. The electricity from the welder will not short to the actual earth ground.
