RDomeij
    Sun Mar 08, 2020 2:47 pm
My boss, who is not a welder, has just asked me to find a way to weld studs using out stick welder.
The reason we need a stud welder is because the surface we're welding to is under 6" of insulation; we're attaching studs to it.
There's no way they're going to buy a stud welder.
Please help me
That’s going to take a lot of welder, and a lot of practice. Even if you do thousands of tests and do get it to work it’s not going to stand up to any engineering standards, without years of documentation.
    Sat Feb 17, 2018 10:10 pm
    Carberry, Manitoba, Canada
I was was looking for the same thing a few years ago. Maybe just buying a stud gun and connecting it to a stick welder. That was pretty short lived when I found out most stud welders go well above 1,500 amps. I have yet to find a stick welder that will do that...
tweake
    Mon Dec 18, 2017 4:53 am
    New Zealand
RDomeij wrote:because the surface we're welding to is under 6" of insulation;
what type of insulation ?
BillE.Dee
    Mon Nov 27, 2017 8:53 pm
What are you wanting to weld the studs to? What kind of insulation? What are and How heavy are the "studs"? What are the studs going to hold? Horizontal, vertical, overhead?
clavius
    Wed Sep 21, 2016 9:32 pm
    NE Massachusetts
If you really want a DIY solution take a look here. While this is not exactly what you are looking for it may be a starting point:
https://books.google.com/books?id=9yADA ... er&f=false
cwby
    Wed Nov 13, 2019 7:07 pm
They rent them & the ones they have have already been designed, tested & work!
https://www.red-d-arc.com/rental-equipm ... ub_cat=180
