9rpcrowe
    Fri Dec 25, 2020 12:24 am
I just have got a brand new AC DC stick welder and I am new to stick welding.
I have decided that I'm going to keep on hand 6010 and 7018 in 3/32 and 1/8 maybe some 5/32 but I know that the 7018 is the one that I need to keep out of the moisture.
    Mon Feb 26, 2018 1:52 am
    Idaho
If you are not doing code work it doesn't matter. Try to keep your lo-hydrogen rods in a sealed container, but if you go out and do something you deem critical, safety concern potential, or is a coded weld, get new rods.
Of course there is also rebaking and rod ovens, but that is expensive if you aren't welding with 7018 daily.
Edit: Yes keep all the rods dry and out of moisture as much as possible. Get some sealed rod guards if you are really worried, otherwise just keeping them in ziploc is good to go.
Spend a couple of bucks and get a few of these: https://weldingsupply.com/cgi-bin/einst ... :RG-100-24
You can get different colors for varying rod types and use a Sharpie and notate the top with the diameter. Makes it easy to grab and go, keeps them dry and protected from the flux being knocked off, and keeps you well organized.
    Thu Dec 26, 2013 12:41 am
    Laredo, Tx
If you have a harbor freight near you, thise rod canisters are $4 ea. :)
tweake
    Mon Dec 18, 2017 4:53 am
    New Zealand
i'm a little crude, i just store them in the hot water cupboard. that keeps them dry enough.
you also can get those little packets that soak up moisture and put them in the tube.
Olecoot
    Thu Nov 26, 2020 10:01 pm
    Somerset, Texas
old refrigerator with a 60 watt light bulb works good too, just make sure the light is always on
Fame is vapor, popularity an accident, riches take wings. Only one thing endures and that is Character.
Olecoot wrote:old refrigerator with a 60 watt light bulb works good too, just make sure the light is always on
Dang, that's gotta be heavy to tote to the field or a job site... :o :lol:
Olecoot
    Somerset, Texas
Builds muscle and endurance :mrgreen:
Olecoot wrote:
cj737 wrote: Dang, that's gotta be heavy to tote to the field or a job site... :o :lol:
Reminds of my reply to folks when they ask: why do you carry a firearm? Because a cop is too heavy!
BugHunter
    Sun Apr 19, 2020 12:54 pm
Oscar wrote:If you have a harbor freight near you, thise rod canisters are $4 ea. :)
You got a link to them? I can't find em on the site.
Spartan
    Fri Mar 06, 2020 8:59 pm
If you're not doing code work, and if you may not be doing professional-level work where 7018 is required, recommend you give some thought to running something like 6013 or 7014. They are arguably easier to run, and don't have the stringent storage requirements. Not trying to assume your needs, though.
However, I have noticed a lot of beginners thinking they have a need to run 7018 because that's what they see the pros running. If you don't actually need the added hassle of 7018, why force it on yourself?
G-ManBart
    Sat Aug 01, 2020 11:24 am
9rpcrowe wrote:I just have got a brand new AC DC stick welder and I am new to stick welding.
My shop is has heat and A/C, so fairly well climate controlled, but far from a rod oven. I have two partial 50lb tins of 7018 that have been opened for at least two years....one is ESAB Atom Arc and the other Lincoln Excalibur. They weld just like when I opened the cans. The only thing you might notice is fresh rods right out of an oven tend to be easier to start...sorta preheat for the rod. For code work you'd want fresh rod, rod ovens, and rod canisters to hold the rod when removed from the oven, but most of us aren't doing anything along those lines.
While other rods might make more sense for some folks, 7018 is easy to find, cheap and is a known quantity so it's often simpler for folks to just stick with it...no real downside for anything but code work.
Miller Millermatic 350P
Hobart Champion Elite
Everlast PowerTIG 210EXT
Honestly even at the nuke plant they buy in bulk but vacuum pack smaller amounts of rod in plastic bags. No need for a rod oven.
https://www.amazon.com/gp/slredirect/pi ... ame=sp_atf
    Idaho
Spartan wrote:If you're not doing code work, and if you may not be doing professional-level work where 7018 is required, recommend you give some thought to running something like 6013 or 7014. They are arguably easier to run, and don't have the stringent storage requirements. Not trying to assume your needs, though.
I don't totally agree here. I feel that 7018 is a good general purpose rod and being able to run in all position is a plus. I much prefer it to 7014 and 6013 that is for sure. I have nothing against 6013, but I feel those rods are much more slaggy and if I'm going to weld with stick instead of tig I usually just reach for 7018. It what most of us learned in school and did the majority of our practice with. In my opinion there are no storage requirements for 7018 if you are not welding to code. Just keep them dry and in a somewhat sealed container.
All welders should remember use their most valuable tool (their brain) to determine when a job is over their head. Think of the consequences of what you are doing. If it's life support and you aren't at that level don't weld it.
    Laredo, Tx
I'll be damned, they don't have them anymore! Shame.
Weldingsupply.com has them and their shipping is reasonable if you were to buy at least 6 of the canisters. $5.77/ea. If you order say 10 of them, shipping is only $12. If you buy 1 shipping is $10.
BugHunter
Ok, I thought maybe it's an in-store item only, and I've not had time to get to the store.
I'll stick em on the wishlist at WS. Thanks all the same!
