logansalazar
    Sat Dec 24, 2022 10:32 pm
thanks in advance
i have a black face swaped with a perkins 3 cylinder and recently had problems with my starter so i put a new one on and i now the machine is completely dead nothing happens when i press the start button i have 12.6V going to starter ignition switch is not bad i hook up jumper cables to battery the start button will crank now but wont fire off, the machine will fire off if another machine jumps it (ground to ground and stinger to stinger) only way i can get it to run
anyone else had this problem or might know whats wrong
checked all the wires, its getting fuel and has oil pressure
