jasonw74
    Fri Feb 26, 2016 9:16 pm
Hi guys,
I have a lil cheap flux core 120 wire feed welder that is not worth replacing the wire feed motor and the cord the wire runs through has snapped in half. So I am going to upgrade to a Mig welder soon.
My question is, can I turn this Flux core 120 into a stick welder. Can I just get a Electrode Holder w/Cable and attach it to the flux core machine> It is an AC unit.
Any help would be appreciated.
    Fri Jan 09, 2015 8:11 pm
    Northeast Tennessee
The type of power supply for GMAW and FCAW is a constant voltage power source. The type needed for SMAW and GTAW is a constant current power source.
The response of the machine to variations in arc length would make welding with stick/tig on a CV power source extremely difficult.
But hey, give it a try if there's nothing to lose.
I have never tried it other than by accident when using a multiprocess machine but based upon the electrical theory behind the processes, its not happening.
If that were all there was to it, you would see most machines marketed as MIG/Stick.
Gerald
Gerald Austin
If I didn't say it in the post- Have a great day !
Greeneville Tn
Welcome!
And, nope, not in any practical way. Your wire feed welder is a constant voltage source, varying the current with your wire speed and stick-out..
A stick welder is a constant current source, with the voltage adjusting instead to maintain the output power.
Apples and oranges.
