There probably is its going to vary depending on the composition of the flux. You may have to run a few passes to see what you can get away with. I think the stuff we used had a pretty thick slag on it when you were done. And it had to cool a bit before it would chip off.
Woodbutcher
- Woodbutcher
Thanks for your time this evening. I'll give er a try tomorrow and if anything real crazy happens ill keep you posted. I still havent got the results back on the one inch exray test, but I expect to see them anytime.
Is it just me, or does it seem to others... When you're entirely confident in your test coupon the results come back very fast. When you're less certain, the lab seems to drag it's feet? Is it a real correlation, or just perception?
Woodbutcher
- Woodbutcher
So preheat is a must, then the hardface 50 rods run smooth as silk. Without preheat I couldnt weld for an inch without hearing popping and snapping from welds breaking, like possibly the very same weld I was working on.very interesting job,, especially when trying to sew up a five foot seam.
- DLewis0289
When I had "nothing to do" when I was younger. Dad used to just roll the buckets on equipment and make me go out and hard surface the bottoms of them basically out of position. Huge pain in the rear, if you are flat easy as pie, drag, criss-cross, diamonds and write profanity with it.
