Hi again!
I just got hold of some 6013 1/8 rods, and tried welding 6013 again. Seems I might have held to short an arc, because when I lengthened the arc a bit the slag pushed back in the puddle. If I held a short arc the slag would kind of catch the edge of the rod and start to solidify, and the puddle was hidden below the slag all the time. Felt like welding blindfolded. And the beads looked better when I held a longer arc. I was welding on clean scrap 1/4" plate.
Seems there is a sweet spot there, however I still prefer 7018´s. They make tougher welds too, so Ill stick(haha) to them!
Thanks for all advice!
Jonathan in Sweden
Jonathan in Sweden
joseph.mowery
- joseph.mowery
6013 is a general purpose mild steel rod designed and fluxed for AC "crackerboxes", and is often called "farmer rod" for its frequent use in agricultural repair. I've experimented with it (don't ask why... I was bored) and it does perform much better on AC. Perhaps for similar reasons to aluminum? DCEN and DCEP did not produce good or even consistent results.
Steve
Steve
