I made this the other day for a different reason, but found it is good for clamping small parts for welding.
Reason I made it. about once a year I need to replace the rubber blades on my snow thrower. To install the end bolts you have to flex the rubber blade to get the bolt far enough in to get the nut on then turn the bolt to get it to thread on all in a tight space. The point on the tool fits into a small hole in the head of the bolt allowing it to be clamped and still turn. will find out if the plan works next time I change the blades.
I can't seem to add two photos so I will make a second post
and I thought I was talented.Warrenh wrote:Its been a busy two week span. 4 spiral staircases and a poling platform. You really cant complain about being busy.
- 5th Street Fab
Hey guys some pics from the last month or two I hope everyone has a merry Christmas!
1st pic is a seat hinge
2nd pic is a gutter with a gusset I added
3rd pic is an inset door latch
4th pic is just a long box that's MIG welded on the inside and just autogenous welded on the outside, I use small back and forth motion to get the ripples.
5th is the baffles from the inside of a fuel tank. Bottom weld is MIG side is tig.
6th is an air duct for a 67 cougar
7th is some bungs in a fuel tank.
8th and 9th is a boarding ladder bracket
Sent from my XT1635-01 using Tapatalk
- 5th Street Fab
1st pic is some end caps
2nd is a drain
3rd is just some MIG
4th is a hard 90° elbow and 5th pic is the penetration of it
6th is some mounting points
7th is a steering box
8th is a transom drain plug
9th is a Y for a fire boat house and flange
2nd is a drain
- 5th Street Fab
Damn! 5th.. Nice work Man.. Makes me want ti get out there and practise some more, and more, and more.. LOl
Pete
- 5th Street Fab
- 5th Street Fab
these were all done with your technique of “Jam on the peddle, feed rod, move,wait,jam on peddle, feed rod,move, wait...etc??aland wrote:Those welds are looking pretty spanky there 5th Street!
- 5th Street Fab
No just consistent foot pedal add filler mover add filler move etc. I do use that technique but only when it's very thick and not preheated.Cncdave wrote:these were all done with your technique of “Jam on the peddle, feed rod, move,wait,jam on peddle, feed rod,move, wait...etc??aland wrote:Those welds are looking pretty spanky there 5th Street!
Moving my wastegate straight to the turbine housing for real boost control, the WG is so huge (V60) that I didn't have a nice way to dump it so I decided to do a smokestack. Can't wait to hear how it sounds (in addition to the 4" Ti side exit exhaust I plan to do)
Also haven't done aluminum for a while so didn't want to get rusty. I'd been looking for a calf raise for my basement gym but haven't found anything reasonably priced that isn't shit. So I picked up a few pads, a pair of pillow bearings, dug through my metal supplier's offcuts for 1/4" tubing and made my own. Even put to use the spare shift knob I got with my 4 speed. I sorta expected it to fail as I use a lot of weight for calf raises but it's giving me faith in my work. The middle thigh pad post sees a lot of load and been serving me well
- r0nJRYI.jpg (51.43 KiB) Viewed 3773 times
- csC8JOL.jpg (48.49 KiB) Viewed 3773 times
- weI0oBW.jpg (51.43 KiB) Viewed 3773 times
I understood.Cncdave wrote:Sorry, pedal.[WINKING FACE]
I'm going to give that method a try for a welding cart I am going to build.
As you jam on the pedal, I'm guessing you watch the puddle for it to get bright, and feed the rod, then move the arc forward, pause briefly and shampoo, lather rinse, repeat ???
I'm gonna practice on some scrap first, and will test various things out...the pedal seems better than using pulse, but I've seen people using 1-1.5 frequency on the pulse to get a similar effect.
My angle grinder died... which sucks. I bought one off ebay, but it hasn't arrived yet.
EDIT: Never mind, I found this video that Jody did. Seems Jody push the rod in as he pulses the pedal.
Alan
- 5th Street Fab
Ya kinda like that. With aluminum you're adding quite a bit of filler. I step on the pedal and start adding filler until the puddle is as wide as I like then taper off on the pedal while still adding filler until the puddle is calm then rinse and repeat. It all takes less then a second so it takes a bit of practicealand wrote:Cncdave wrote:these were all done with your technique of “Jam on the peddle, feed rod, move,wait,jam on peddle, feed rod,move, wait...etc??I understood.Cncdave wrote:Sorry, pedal.[WINKING FACE]
Alan
Just messin around with some stainless
- sq1920 20180119_134513.jpg (57.99 KiB) Viewed 3627 times
- tungstendipper
Look'n good Billy Ray.
Everlast 210 EXT
CJ737
Everlast 210 EXT
CJ737
+1
Looks really nice work & it's great when a familiar name returns on the forum - sadly a few have fallen recently - more newbies here now than vets.
Do keep posting pics if only to remind me how bad my eyesight is & Tig is best left to the young guns !
