Step 2: Insert collet through rear of torch (hehehe)
Step 4: Cup of your choice on the front, adjust stick out a little, place back cap on the back. Snug down back cap to tighten up the tungsten so it doesn't get crazy on you.
- 0310172213.jpg (26.57 KiB) Viewed 842 times
- Chips O'Toole
The 1/8" collet fits the collet body just fine. That's why I thought it was weird that the tungsten would not go through the collet body.PeteM wrote:Does the collet for the 1/8 tungsten fit into the collet body?
When they're brand new, before everything gets hot and cold a few times, they can be a little snug. I don't know if anybody does it any differently, but I find it helps to do them in that order so that you can give the tungsten a good shove when it needs it.Chips O'Toole wrote:The 1/8" collet fits the collet body just fine. That's why I thought it was weird that the tungsten would not go through the collet body.PeteM wrote:Does the collet for the 1/8 tungsten fit into the collet body?
Hope that helped, and happy tiggin'.
CanMoulder
- CanMoulder
each size tungsten has a specific collet body size
so if you change the tungsten size you have to change the collet and the body
https://images-na.ssl-images-amazon.com ... nWLQPL.jpg
also the paint on the end of the tungsten can be to large if trying to slide in from the open end
Kevin
Kevin
