Page 111 of 131
Posted: Wed Aug 16, 2017 9:37 pm
by 5th Street Fab
Onenastycummins wrote:this looks sick, what kind of machine you use?
Thanks everyone.
I run syncrowave 250dx's
Posted: Thu Aug 17, 2017 5:24 am
by motox
5th st
what do you use to cutout the aluminum parts?
Posted: Thu Aug 17, 2017 9:22 pm
by 5th Street Fab
motox wrote:5th st
We have a router table for the main parts. Then we just use a shear or band saw for everything else.
Posted: Sun Aug 27, 2017 6:13 pm
by GreinTime
Some 9th Gen Civic Turbo manifolds getting done after hours.
Posted: Fri Sep 01, 2017 12:07 am
by dirtmidget33
Posted: Fri Sep 01, 2017 5:47 am
by AndersK
Good to see you back again midget
Looks like a nice project, I like anything that will include smoke, fire and the possibility to explode
Fire mission danger close
Posted: Sat Sep 02, 2017 12:41 am
by dirtmidget33
Thanks Andersk, it has been too long. There is a lot to catch up on.
Since you like things that explode you might like this one. Has nothing to do with welding though. These are some six inch shells from a New Years shoot.
- FB_IMG_1504326930445-1.jpg (44.52 KiB) Viewed 3795 times
Posted: Sat Sep 02, 2017 4:45 am
by AndersK
Hell yeah
Looks more like the powder charges they used on
pirate ship cannons.
Posted: Sat Sep 09, 2017 11:16 pm
by GreinTime
Riding the gravy train on a Saturday night! 3/32 tungsten, #8 cup w/gas lens since I couldn't make it happen with a straight collet and #6 cup, and 4943 filler. Roughly 1-1.25rpm on the positioner with the welder set at 175, probably only using 100-125 as it gets to the end of the weld.
Posted: Sun Sep 10, 2017 7:51 am
looks real good Sam, are you just tacking and welding or doing the cutting of the pipe also?
Posted: Sun Sep 10, 2017 11:32 pm
by GreinTime
LtBadd wrote:looks real good Sam, are you just tacking and welding or doing the cutting of the pipe also?
I cut the tubes on a lathe and then used a miter gage on a belt sander to sand the angle. This was all done before I left on Friday, I just took everything home to weld it.
Posted: Mon Sep 11, 2017 10:27 pm
by mpete53
I love seeing all the great looking weld posted here. Myself, I wanted to learn tig welding to do small fabrication and repair of stainless steel parts for boats. Today I was able to help a friend by welding a mount back onto a porthole frame. Not a lot of welding just 4 tacks from 16 gauge to .025. While it was not the best looking weld it made him smile.
also 2 other small boat projects
Posted: Sat Sep 16, 2017 11:28 am
by 5th Street Fab
Posted: Sat Sep 16, 2017 11:35 am
by 5th Street Fab
Posted: Sat Sep 16, 2017 2:17 pm
by motox
5th St.,
not only do you do outstanding welds but your shop fabs the neatest
projects!!
Posted: Sat Sep 16, 2017 3:04 pm
by 5th Street Fab
motox wrote:5th St.,
projects!!
Thanks bud I really appreciate it!
Posted: Sat Sep 16, 2017 3:07 pm
by 5th Street Fab
projects!!
Posted: Sun Sep 17, 2017 2:27 pm
by ESENTI
Seems perfect well done.Very nice bright welding I wonder what is the flow of argon gas protection isi perfect and how you can achieve this king of shine weld apart the skill that it is obvious that is outstanding...Bravo.. Some how o pro must show
quality of welding that is ahead of the average welder .
Posted: Sun Sep 17, 2017 6:36 pm
- IMG_2460.JPG (73.35 KiB) Viewed 3560 times
Started working last night on a 16 inch 300# steam main under ground. There still digging up pipe trying to find the leak. It has an insulation case and a welded 24inch jacket. If they can't find the leak visually then there going to bring in a smart pig. It's a robot that can ultrasound the pipe from the inside. Either way we will be cutting off the jacket and repairing the pipe, or cutting out some holes big enough to get the robot in. We only have a one week window so it may not all happen this week. I'll post more pics as I can.
Posted: Fri Sep 22, 2017 12:35 am
by 5th Street Fab
Posted: Fri Sep 22, 2017 8:05 am
by motox
5th st
i see you do numerous shapes and fixtures.
do you have several customers or do you build for one source?
Posted: Fri Sep 22, 2017 2:52 pm
by 5th Street Fab
motox wrote:5th st
I work for North River boats so most of the things you see are for them.
Posted: Sat Sep 23, 2017 7:04 am
by motox
5th st
awesome array of projects.
Posted: Sat Sep 23, 2017 8:25 pm
by Jakedaawg
@5th Street Fab
Just out of curiosity, are the long runs that you do done with mig? Do you use both processes?
Posted: Sun Sep 24, 2017 11:01 am
by 5th Street Fab
Jakedaawg wrote:@5th Street Fab
It depends. I try to tig anything that will be seen or anything that's critical. Everything else is migged.
