mpete53
    Sun Mar 06, 2016 11:33 am
    New York
I was playing around and tried a couple ways of protecting the back of the weld and thought that some might be interested in my tries
Yes I know my stainless still does not shine, but cleans up nice with a wire brush.
I made a aluminum foil tray then using 20 seconds of post flow filled it with argon before welding
The first photo shows the aluminum foil tray with the spoon handle inside
the second shows the top of the welds. the right weld was done a different way
the third shows the bottom
the forth shows the bottom brushed
Spoon handle unknown stainless
30 amps
15 cfh
no filler
not wiped down with acetone
That far right weld was done by using modeling clay on the bottom. It made lots of smoke and an odd shaped weld but no sugaring
bottom brushed.jpg (24.17 KiB) Viewed 485 times
