I took a rod and tapped it against my chest to move it in my fingers and had the hot end towards me... Cauterized a nice hole in my chest.
We were always taught to do it at school for safety reasons - as much as to know which end was hot as poking oneself in the eye ! this was for gas welding as my time at school predates Tig ! I have'nt bent filler rod ends in years but several times I dropped the filler off a bench went to pick it up & found 1'8" silicon bronze wire holds heat better than you expect - got several shiny lines on the fingers to prove it - so it's not a daft practice - on;y thing against is I also weld stubs together with bronze rods as the price here is crazy expensive - regular ER70 I never bother as it's cheap.
- Farmwelding
Is it worth the argon or the time?motox wrote:I tack my rod stubs together and use 'em. Waste not, want not.
LIKE!
- MosquitoMoto
I suspect it isn't, but I used to do the same thing.Farmwelding wrote:Is it worth the argon or the time?motox wrote:I tack my rod stubs together and use 'em. Waste not, want not.
LIKE!
Started doing it when I began welding, just to prove I could. Nowadays, because the cheap runs deep in me, I tend to grab the stub in a needle nose locking pliers to feed it into the puddle down to the last tiny bit, then junk the micro-stub.
Kym
- Farmwelding
Well at my high school some of the kids decide to hang the tig torch on the side of the weld stand that was exactly in the best place but nonetheless the welding helmets say right next to it so now there is plastic on the ceramic cup and a few valleys in the shell of the helmet. And kudos for grabbing the pair of pliers I guess. Never thought of doing that and might have to try it now.
I only tack aluminum or SS rod back together because the carpenter in me hates to waste material but I bought a bunch of rod from a retiring welder so I have tons of rod now and I will use the needle nose manuever too.
- Farmwelding
I swear you find the best and the most deals of anybody I know. Band saws on the street a bulk of filler. Wish I had your luck.exnailpounder wrote:I only tack aluminum or SS rod back together because the carpenter in me hates to waste material but I bought a bunch of rod from a retiring welder so I have tons of rod now and I will use the needle nose manuever too.
- MosquitoMoto
This little Vise Grips is now used exclusively as a holder for the stubs of rods as I use them down the the last little nub. It's really nimble and easy to use. Using these, I can add the filler to the pool all the way until it reaches the little flat '5356' stamping on the rod.
The Grips possibly wouldn't be much good for anything else by now anyhow...they've seen a lot of heat!
Kym
It's funny you say that. Work has been really slow and I might have to go get a job but my wife keeps telling me to hang in there and 2017 is going to be my year and now all of a sudden I am finding all these great deals/pickin treasures so hopefully she's right. I can't see myself ever going to work for a bosshole ever again at my age and my serious lack of tolerance for bullshit but the days are looking brighter.Farmwelding wrote:I swear you find the best and the most deals of anybody I know. Band saws on the street a bulk of filler. Wish I had your luck.exnailpounder wrote:I only tack aluminum or SS rod back together because the carpenter in me hates to waste material but I bought a bunch of rod from a retiring welder so I have tons of rod now and I will use the needle nose manuever too.
- maker of things
1) Safety but more often for me 2) if you lay the filler down on the table (or dropped on floor), you can give it a little roll and the hook end stands up and can now be grabbed, even with gloves.
-Jon
Lincoln Viking 3350 K3034-2&3
Lincoln Power Mig 180c
hermit.shed on instagram
Does the 5 second rule apply to filler wire the same as it does for food?maker of things wrote:1) Safety but more often for me 2) if you lay the filler down on the table (or dropped on floor), you can give it a little roll and the hook end stands up and can now be grabbed, even with gloves.
- maker of things
And like vacuuming, how many times will you try before you finally just take your glove off like you could have the first time?
-Jon
I will grab my pliers before I take my glove off. That would be admitting failuremaker of things wrote:And like vacuuming, how many times will you try before you finally just take your glove off like you could have the first time?
But we still try to pick it up with our gloves on for a little while like dumbassesOlivero wrote:I will grab my pliers before I take my glove off. That would be admitting failuremaker of things wrote:And like vacuuming, how many times will you try before you finally just take your glove off like you could have the first time?
Alwaysexnailpounder wrote:But we still try to pick it up with our gloves on for a little while like dumbassesOlivero wrote:I will grab my pliers before I take my glove off. That would be admitting failuremaker of things wrote:And like vacuuming, how many times will you try before you finally just take your glove off like you could have the first time?
Us welders ain't too bright but we catch on eventually
- maker of things
That is good to hear, can't wait till it happens to me...exnailpounder wrote:Us welders ain't too bright but we catch on eventually
-Jon
The light starts to come on after the first time you forget to put the ground on your work and the High Frequency zaps your ass to remind you. That will wise you up quick but the glove thing takes longer to figure outmaker of things wrote:That is good to hear, can't wait till it happens to me...exnailpounder wrote:Us welders ain't too bright but we catch on eventually
Not nearly as long as remembering to turn on and off the gasexnailpounder wrote:The light starts to come on after the first time you forget to put the ground on your work and the High Frequency zaps your ass to remind you. That will wise you up quick but the glove thing takes longer to figure outmaker of things wrote:That is good to hear, can't wait till it happens to me...exnailpounder wrote:Us welders ain't too bright but we catch on eventually
I make it a habit when I walk by my welders to twist the knob and make sure the bottles are off and I'll be damned if I checked my Mig the other day and it was left on. I used it for 5 friggin minutes and forgot to shut it off. Maybe I should cut back to only a fifth of vodka a day or only a case of beer instead of 2...or not
- Farmwelding
No expert on health or medicine but it may help you remember to turn off the gas. And will save you money on gas.exnailpounder wrote:I make it a habit when I walk by my welders to twist the knob and make sure the bottles are off and I'll be damned if I checked my Mig the other day and it was left on. I used it for 5 friggin minutes and forgot to shut it off. Maybe I should cut back to only a fifth of vodka a day or only a case of beer instead of 2...or not
JFF45
- JFF45
Until I finally bought my own gas bottles, I was getting gas from a company here called Air Liquide and their bottles just had a red lever to open/close which I thought was a really good idea because you could see at a glance if the bottle was open or closed.
The last argon refill I got has such a hard tap I need two hands to open/close it..
John
