I hope you're not breathing zinc fumes.Poland308 wrote:I've been welding on some zinc coated nuts for a side project. Finished a few welds while I had blobs big enough they were touching the edge of my #7 cup. Good enough for a garden cart.
- Chips O'Toole
Those are ok. I do mine by hand on a Harbor Freight 3" mini grinder.Chips O'Toole wrote:My tungsten arrived. I decided to throw one on the belt grinder. Does this look all right?
I held it in a drill, to turn it while I ground it. Kind of surprised it's not completely symmetrical.
bigfabdaddy
- bigfabdaddy
My 2017 AHP Alpha TIG will be here tomorrow between 9:15am and 1:15pm. I work from 10am-4pm then class from 5pm-9pm. Planning on getting it set up tomorrow night then start practicing between classes so I can be a better tig welder than anyone else in the class.
Lincoln SP 175 Plus
AHP Alpha TIG 200X (on the way)
Oxy/Acetylene Torch
Oxy/Acetylene Torch
bigfabdaddy
- bigfabdaddy
What do you mean by hand? Just hold them in your fingers and give them a little rotation while you put them to the grinder? I ordered a Wen 6" grinder to be my dedicated tungsten grinder. I have yet to grind a tungsten, I will be shown how tomorrow during the class when we go over the tig machines that are sitting in the shop.Oscar wrote:Those are ok. I do mine by hand on a Harbor Freight 3" mini grinder.Chips O'Toole wrote:My tungsten arrived. I decided to throw one on the belt grinder. Does this look all right?
Lincoln SP 175 Plus
Oxy/Acetylene Torch
Oxy/Acetylene Torch
- entity-unknown
If you have a 3d printer or if you've got a school/buddy that has one then you can print a Tungsten grinder for a Dremel. I've been using this quite a bit and it works wonderfully! It's a remesh of someone else's design that was a remesh of someone else's design.
http://www.thingiverse.com/thing:1905626
Lincoln Electric AC225
Everlast W300 WaterCooler
Optrel e684x1
Optrel e684x1
bigfabdaddy
- bigfabdaddy
I have been grinding mine by hand on my bench grinder rather than loading them in a drill and it works amazingly. I got such a nice point on some 1/16 2% lanthinated it makes a super tiny weld puddle on the steel I was playing around on last night. Thanks.Oscar wrote:Yup exactly.
Lincoln SP 175 Plus
Oxy/Acetylene Torch
Oxy/Acetylene Torch
