I have put a sharpened 3/32 stainless rod in place of tungsten once, it just made a mess of everything. Go figure.
- MosquitoMoto
OP -
The first thing I'd try would be to switch back to all standard torch fittings and have a go.
Another idea...do you have a friend with a Tig rig? Can you take your torch setup to him/her and see if it works with their machine?
Rick van winkle
- Rick van winkle
Thanks for all the ideas so far guys. I remived the torch body from the line and i can easily blow through the torch body and the torch hose with my mouth. The flared connection where the torch nut threads onto the hose looks perfect. I dont have any friends who mess with tig at all so im alone on that. Im thinking ill buy another torch head and standard collett setup to go in it and see where that gets me. Even if they arent the problem it wont hurt to have extras.
Rick van winkle
- Rick van winkle
Just to be safe i did double check and ive got the blue stripe on the end still.Rudy Ray wrote:^^^^^^
Least honorable
- Least honorable
Noticed you said you put a gas lens kit after, then it started welding all weird, not beforehand, so 2 things one of which might solve your problems, at my school I was welding with 20cfh and had no problem without a gas lens, when I went to put my own gas lens on it the arc was basically doing what its doing to you, and then I turn on the preflow to like 10s so I can feel the gas, on my palm, and it felt like a gust of wind, no doubt was probably 60-80 cfh, had to put the flowmeter on 3-5cfh for it to act like it was on 20. This was in fact on an an old torch, but might still apply to your case, and having too much gas can be just as bad as having none. So if you want, try to go back with your old setup without the gas lens, see if that might fix it.
As for your collet problem, pretty sure you've figured it out but just in case, I'd you use solid collets, they will virtually never twist (by solid I mean ones with no slit)
Regards
Noah
Regards
Noah
If the problem only started with fitting a gas lens can we see a picture of how you have it fitted ? unless you managed to find the elusive 1piece teflon insulator you fit the one in the gas lens kit WITH the original otherwise there will be a gap where it meets the torch body & atmosphere will be sucked in giving issues like you describe - happens quite often - there are several recent other posts covering it.
I don't use that teflon insulator and I have never had a gas issue. The gas lens threads into the torch handle, and the ceramic cup threads onto the body of the gas lens so how is it possible to draw in air? Through the cup threads? That is the only way it can do it. It has never been clear to me how people are having leaks without using this mystery insulator. On my torch, when the cup is threaded onto the gas lens, there is a small gap but someone needs to explain to me why my torch has never leaked or drawn in air. I have never had a gas problem with this torch or the torch on my other machine that was set up the same way.noddybrian wrote:If the problem only started with fitting a gas lens can we see a picture of how you have it fitted ? unless you managed to find the elusive 1piece teflon insulator you fit the one in the gas lens kit WITH the original otherwise there will be a gap where it meets the torch body & atmosphere will be sucked in giving issues like you describe - happens quite often - there are several recent other posts covering it.
- 20170210_154115.jpg (38.13 KiB) Viewed 1446 times
Rick van winkle
- Rick van winkle
I stopped by my lws on the way home today. Bought some new collets and bodies to go back to my old setup. They also loaned me a torch to try. I just tried the new standard collett setup in my old torch. The problem is still there but the arc is a little more stable but if i try to puddle its instant porosity and sparks. So i put their new loaner torch head on my hose and the issue doesnt change. They sent me a hose too but its doesnt have the right connections for my machine. So i guess the next step is try a new hose? I did move my hose to make it a little neater when i was installing the collett body so maybe a bad connection in the hose is why my arc is a kittle better today? I do have the special teflon washer its part of the weldmonger kit i bought.noddybrian wrote:If the problem only started with fitting a gas lens can we see a picture of how you have it fitted ? unless you managed to find the elusive 1piece teflon insulator you fit the one in the gas lens kit WITH the original otherwise there will be a gap where it meets the torch body & atmosphere will be sucked in giving issues like you describe - happens quite often - there are several recent other posts covering it.
I must have explained the situation a little oddly in my first post. The problem started with the standard collet body setup and i bought the gas lens kit to try and fix it. I originally had just asumed the collett was damaged somehow when i overheated it. That and the collett body being seized in it meant i had to replace it anyway.
Rick van winkle
- Rick van winkle
Yessir! You can see in the pic of my torch that my front insulator is shorter and there is a gap but it has never caused a problem. If you can get her welding, you will love the gas lens. Let us know if you figure it out. Pick up a couple shorter tail caps when you hit the LWS. Very cheap and they come in handy getting in tight spots. Save those stubby little tungstens too...you can use them down to the nub,
I once had gotten the gas line pinched between the bottle and the bottle rack. When you initiated the gas flow you would get the little puff sound and feel the gas flow but then it petered out to so little flow it was worth nothing. It took me a while to figure it out but after moving the gas hose everything went back to normal.
If you over heated your torch it's posible the cable inside your lead melted through the gas hose internally. I've done that. You may have melted enough stuff inside the hose to cause a restriction.
I guess we are all going to have to agree to disagree on the mystical torch cup gasket.
ha, yeah, that's why I said that... I did the same thing once... that's what I get for having a cluttered messy welding table, "oh good, there's a length of tungsten! i'll just sharpen that up..." fail.Rudy Ray wrote:^^^^^^
I think it's safe to say in this discussion that gas is the culprit... I myself doubt the insulator makes any difference at all, and having too much gas flow is a good thought but I doubt that too as it would have to be an awful lot of gas to blow itself out that consistently I would think (?).
But what this does remind me of is a situation many years ago where I was first learning how to weld with MIG, my then brand new bottle gauges were reading the correct flow, but I had similar issues as the OP... I swapped over to a friend's set of gauges who I was sharing the shop with, and problem went away. Turned out my new gauges/hose had some debris stuck inside of them from the factory that allowed gas to flow but at a much restricted rate... Eventually I managed to unclog them and they were fine after.
Rick van winkle
- Rick van winkle
Good idea. I never even looked inside the bottle valve before i stuck the regulator onraticus wrote:I think it's safe to say in this discussion that gas is the culprit... I myself doubt the insulator makes any difference at all, and having too much gas flow is a good thought but I doubt that too as it would have to be an awful lot of gas to blow itself out that consistently I would think (?).
I hope the OP figures it out - but on the insulator debate I'll add I seen a lot of problems caused by it - maybe an unlucky combination of makes / tolerances but without the correct ones you can get either ceramic is done up against end of brass thread & cracks ceramics due to metal expansion / contraction - recent post showed this - always breaks in the same place or by having a gap near torch body the threads can be loose enough that air is drawn in down the thread in much the same way it can on gas line leaks - initially makes no sense but it can & does happen causing much head scratching as to the cause of gas issues - I get any number of people visit me with the common issue " I bought this Tig but it's faulty coz it does'nt weld like Jody's " ! it's usually simple but you have to see it not go by a description of what they think.
Rick van winkle
- Rick van winkle
I think youve hit the nail on the head. Im thinking ive got something in the solenoid valve. Im getting steady argon supply out of the regulator but out of the torch hose im getting a good initial burst of gas that tapers off to a light breeze. I guess im pulling the case.raticus wrote:I think it's safe to say in this discussion that gas is the culprit... I myself doubt the insulator makes any difference at all, and having too much gas flow is a good thought but I doubt that too as it would have to be an awful lot of gas to blow itself out that consistently I would think (?).
Jim FLinchbaugh
- Jim FLinchbaugh
Least honorable
- Least honorable
i've (and im pretty sure many people have) welded with magnets less than an inch away from my weld zone and i've never seen any magnet screw up a weld like that at 10 amps, though thats just me. unless he owns a really powerful rare earth magnet, i doubt its the issue, but what is happening to OP really does puzzle meJim FLinchbaugh wrote:Do you have a magnet anywhere near what you're welding?
Like holding 2 pieces together?
Rick van winkle
- Rick van winkle
Update for anyone who might be interested... no obstruction was found in the gas lines or regulator. The argon solenoid isnt a type that looks easily rebuildable so i didnt take it apart with the machine being so new. The screen on the inlet of the solenoid is clear though. The argon tube inside the machine isn't pinched. I went back to my LWS today to return the torch they loaned me. They insisted i borrow a regulator from them and try it. So i did but no improvement was seen. The LWS has offered to let me bring the machine uo there so they can see the issue first hand and maybe understand what the issue might be. We will also try another argon bottle when i bring the machine up to them. Anyone in the north georgia area should consider lanier welding supply in gainesville. They didnt sell me the machine but have been nothing but helpful in figuring it out. I called ahp today and talked to their tech support, he was also baffled and thinks i have a bad argon tank.
I did notice today when messing with the new regulator that if i turn the argon flow up the arc stops wandering and instead focuses in one spot that is at least 1/8" from where the tip of the tungsten is. Turn argon down to 15-20 cfh the arc stays close to the tip of the tungsten but wanders all over the place. Get the cfh up over 40 and the arc is blowing off the side off the tungsten 1/4" and is loud like a gas torch with a big arc plume and tons of heat. If i try to puddle the base metal with the high 40cfh setting i get less porosity but still not near acceptable.
well so much for my theory... too bad you don't have a welder friend you can bribe to come over (beer is a good bribery) and let them go at it... if they get the same results at least you can't blame yourself.
I know I am new, but this sounds just like what I did last weekend when I installed the stubby gas lens kit. When you installed the collet in the collet body did you put the slit end in first? I put mine in with the slits up toward the cap and it did the same thing. Arc would jump all over the place due to the tungsten not being tight enough creating a poor connection in the torch. I hope you find your issue.
just thought of one thing, not sure if it was talked about or if you used some different scrap... but is this problem occurring on any steel you use? or is it just on this one piece of steel? i'm wondering if you're only having this issue on the one piece of scrap, that maybe there's an issue with it... maybe it's not even what you think it is (i.e not carbon steel)...
