Or dissect a cheap yard - sale window a/c and slide the evaporator coil into an aluminum box....Poland308 wrote:If your going to go that far you might as well solder a tube system to the bottom of your table and run a pump cooler.
- WoodpeckerWelder
"Why is there never time to do anything right the first time but always time to do it again?"
If money isn't a issue go with a copper heat sink if it is go with Aluminum, as stated copper will pull more heat out it will also pull more out of pocket. LOL
Pete
Ditto over done! Yep. Good enough! Yep. Cheap and dirty! Yep.WoodpeckerWelder wrote:Or dissect a cheap yard - sale window a/c and slide the evaporator coil into an aluminum box....Poland308 wrote:If your going to go that far you might as well solder a tube system to the bottom of your table and run a pump cooler.
