Yes, brazing can work. I mentioned that, I think. The issue is prep... Finding every single pinhole leak, and drilling it clean to a size that will accept the brazing filler. At that point of prep, TIG welding is as easy as brazing, IF you can control your heat input. Frankly, I'd have the filler in place like lay-wire, and hit it with 200A for about 2/10 second, like flash-tacking.nelson wrote:Otto/Steve, I agree. Scrap it.
I composed an answer last nite and posted it to the wrong cloud I guess...sure wasn't here. Seems the OP has similar hood time as I do. I'd blow a hole with the first foot press. I suggested use low temp braze and practice thin AL TIGing for the next time you see a job like this.
Am I right about the braze..with good prep and lots of flux if it were an emergency?
Given my choice, I'd still scrap it and build from 1/8"
