donzi426 wrote:Today I tried something and I believe it works. Didn't clean or sand the horseshoes. Raised the heat to 180 Amps. Raised the gas flow to 20 CFH (lowering it just caused a mess). Used 70R-6 filler rod. Concentrated on the arc angle and bingo. Pretty nice weld. The second side wasn't as pretty, but I think by doing the first side it must release some of the contaminants in these shoes. See photos. I want to thank everyone who contributed to my post. Those suggestions did help.
You did not form a proper puddle on both pieces - if you look at the toes of your first pic you can see a distinct lack of fusion.
Maybe you should practice fillets on regular T joints and show them for some tips on tigging them?
[quote="donzi426"]You're right Dave. I do need more practice on fillets. Back to the drawing board:-)[/quote Or use mig. Mig works on anything. Once you paint your project, a couple of iffy welds won't matter to anyone other than another welder looking to start some shit
I love it you can disagree totally about something on one thread and yet pat someone on the back two posts later. Lots of times I will argue a point until I totally understand I'm wrong and then turn 180 deg and run just as hard the other way.
I know I can MIG these shoes, but I'm determined to conquer this project with TIG. Just need to get the right combination. I'll keep you guys posted. Thanks for all your help.
donzi426 wrote:You're right Dave. I do need more practice on fillets. Back to the drawing board:-)[/quote Or use mig. Mig works on anything. Once you paint your project, a couple of iffy welds won't matter to anyone other than another welder looking to start some shit
A grinder and paint will make you the weldor you ain't
But it is always better to weld it good and strong and not need the grinder except for aesthetics
Just wanted to post an update: I found out why I was having trouble tig welding horseshoes. Today I decided to do some more horseshoes, determined to get it right. I do most of my welding in my one car garage so my welder and welding table are side by side. When I closed my garage door I felt a breeze as if the door was open. Low and behold I felt a breeze flowing over my table. It was the side vents of my welder that was shooting air past the area where I weld. I placed a barrier between the welder and table and low and behold I was welding horses without a problem. My bad!!!
Anyway, I want to thank everyone who tried to help with my problem.
donzi426 wrote:Just wanted to post an update: I found out why I was having trouble tig welding horseshoes. Today I decided to do some more horseshoes, determined to get it right. I do most of my welding in my one car garage so my welder and welding table are side by side. When I closed my garage door I felt a breeze as if the door was open. Low and behold I felt a breeze flowing over my table. It was the side vents of my welder that was shooting air past the area where I weld. I placed a barrier between the welder and table and low and behold I was welding horses without a problem. My bad!!!
Good to know, now if you have other issues I guess you'll already have a good start with trouble shooting tips.
Gosh that only took 5 pages. It happens. My mig welder quit welding on me the other day. I tore it apart and cleaned it out, cleaned out the liner and did everything I could think of and it still wouldn't weld or give me an error code. After I got the manual out, all I had to do was change the contact tip She welds like a dream again for 69 cents.
