Well up here, in the north it is currently warm out (25 degrees F), and generally the only source of heat in the shop is the welder... So, i always wear gloves....
What exactly does a gaslens do, that the regular setup doesn't?
flytyer232
- flytyer232
flytyer232
- flytyer232
Okay, i guess i will hold off on that for now, though i did order some spare parts for the torch (collets, and cups), as i will probably break a few.....
- Farmwelding
Don't drop the torch and you shouldn't have to worry about them breaking. I guess you may need some other collets for the different size tungstens.flytyer232 wrote:Okay, i guess i will hold off on that for now, though i did order some spare parts for the torch (collets, and cups), as i will probably break a few.....
flytyer232
- flytyer232
Oh, i will try not to do that.... So you need different size collects for different size tungsten?
- Farmwelding
Yes sir. Can't got an 1/8" in a 3/32" and sure as hell can't get a current out of a .040" tigster with a 3/32" collet. And a gas lens helps shield the arc and your tungsten better. Look up some pictures and look do the ones that show gas coming out of the torch.flytyer232 wrote:Oh, i will try not to do that.... So you need different size collects for different size tungsten?
flytyer232
- flytyer232
Okay, will get some of those. Should 5 collets, and 2 collet bodies (in each size) be okay for a couple of months? The reason i ask, is the like to place large orders, as it is hard to find that stuff in town.....
Grab yourself one of Jodys Stubby Gas lens TIG kits. It comes with cups and gas lenses, collects and tungstens in each size to get you going. Plus, spending upon the bundle, you get a TIG finger that is useful when you get cranking on heavy material.
The UV burns the epidermis making a stench that doesn't wash off. And the arc burns are deep. I only go bare for tacks under 50 amps. I weld thin stuff mostly but still glove and cover for most. Shade #9 is my standard but have gone as low as 7 ..only for 28 gauge stainless.flytyer232 wrote:Hum.... I don't know that i would weld without gloves, as i have gotten bad burns with gloves (dual shield flux core....). How do the UV light affects your hands?
So i shouldn't worry about getting a gas lens kit (whatever that is, though i hear Jody marketing them all the time)?
thanks,
Mike
