sledwrenchin
- sledwrenchin
I would highly recommend active heat-sinking. A round, small-diameter shaft will dissipate argon faster than almost any other joint (except for maybe an outside corner joint), so you have to be in total control of heat input. Depending on the level of acceptable oxidation, a #12 might or might not get you by. If you're going to spring for a large cup, why not just go larger? You can get #14, #16, #18, and #24 size cups for a better safety margin.
- Farmwelding
would this humorous 150Oscar wrote:I would highly recommend active heat-sinking. A round, small-diameter shaft will dissipate argon faster than almost any other joint (except for maybe an outside corner joint), so you have to be in total control of heat input. Depending on the level of acceptable oxidation, a #12 might or might not get you by. If you're going to spring for a large cup, why not just go larger? You can get #14, #16, #18, and #24 size cups for a better safety margin.
Cup be sufficient with 100 CFH? Or could you get by with 60 CFH for normal regulators
- image.jpeg (72.71 KiB) Viewed 657 times
I think it's worth saying in this case, even with a dark straw or blue color, remember the bead will be machined, so the top .XX" will be coming off.Oscar wrote:I would highly recommend active heat-sinking. A round, small-diameter shaft will dissipate argon faster than almost any other joint (except for maybe an outside corner joint), so you have to be in total control of heat input.
