It is currently Wed Jan 24, 2018 1:19 am Advanced search
Tig arc will not hold and cuts out at low amps.
Postby Danylo66 » Mon Apr 10, 2017 10:24 pm
After welding for a half hour all of a sudden by tig welder will not hold an arc at low amps.
Its frustrating.
Has anyone experienced this problem?
Checked my ground checked and replaced my tungsten adjusted the gas. Pulled my hair out and cried.
:oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :cry: :cry: :cry: :cry:
Danylo66
Re: Tig arc will not hold and cuts out at low amps.
Postby Danylo66 » Tue Apr 11, 2017 2:15 am
Waiting on an answer from Everlast. Maybe something is out of sinc.
Danylo66
Postby LtBadd » Tue Apr 11, 2017 4:52 am
What amperage are you welding at, and what size tungsten are you using?
Insert witty, sarcastic, or philosophical remark here.
LtBadd
Postby Danylo66 » Wed Jun 28, 2017 1:05 am
I use to be able to weld down at 10 amps with 1/16 electrode. now I cant weld below 30 amps. it just starts and fades away.
I have tried Lanthenated Thoriated Ceriated and E3 no luck. cleaned the ground and changed the collets. tried a new tank of argon. I know its a cheap Chines welder, but still it did work and nothing inside looks burnt. I am saving up for a better welder, but in the mean time id still like using this one.
Danylo66
Postby MarkL » Wed Jun 28, 2017 12:25 pm
Danylo66 wrote:Waiting on an answer from Everlast. Maybe something is out of sinc.
There is a welding forum at tractorbynet.com, one of the sponsors is Everlast and there's a company rep on there that is very active helping people resolve problems. You might check that out and see if he can help you.
Lincoln Square Wave 200
Lincoln 225 AC/DC
Harris Oxy/Acetylene torch
MarkL
Postby pgk » Thu Jun 29, 2017 9:30 am
I forgot about Tractorbynet, I used to frequent that forum quite a bit b4 I bought my compact diesel.. Good info over there.
Pete
Esab SVI 300, Mig 4HD wire feeder, 30A spool gun, Miller Passport, Dynasty 300 DX, Coolmate 4, Spectrum 2050, C&K Cold Wire feeder WF-3, Black Gold Tungsten Sharperner, Ellis 1600
pgk
Postby Danylo66 » Thu Jun 29, 2017 4:22 pm
Thanks for the info guys. I'll try that tractorbynet forum.
Danylo66
Postby Artie F. Emm » Thu Jun 29, 2017 5:44 pm
Everlast Canada is located in Burlington, is that near you? I'm sure they could help.
EVERLAST WELDERS CANADA
5109 Harvester Rd. Unit A2
Burlington, ON L7L5Y9
Phone:905-637-1637
Dave
aka "RTFM"
Artie F. Emm
Postby raticus » Thu Jun 29, 2017 9:18 pm
I'm curious, what are you welding that you're only using 10 amps for? I don't think I've ever welded at that low a setting... that must be some really really thin stuff
am I the only one that can't feed filler rod with magical thumb action?
raticus
Postby Danylo66 » Thu Jun 29, 2017 11:28 pm
I was just stating that the machine was capable of welds down to 10 amps. Razor blade challenge.
What I would like to try is to weld 18-22 guage sheet metal. For automotive repair.
Danylo66
