It is currently Tue Jan 16, 2018 11:02 am Advanced search
Two puddle tig
Two puddle tig
Postby neopolythe » Thu Apr 20, 2017 8:36 am
Hello,
I am having an issue on welding aluminum inside corner joints. I strike the arc and when the puddle(s) start to form, instead of me getting a puddle in the root of the corner, I end up with two separate puddles on each piece of aluminum, and the only way I can get them to join up is to add filler rod to one or both until they meet.
What am I doing wrong?
David.
neopolythe
Re: Two puddle tig
Postby LtBadd » Thu Apr 20, 2017 2:40 pm
Nothing wrong...
when you first start the weld, the AL is cold and sucking the heat away quick, so it'll take longer to form a puddle. If you're welding thicker material you can preheat.
Insert witty, sarcastic, or philosophical remark here.
LtBadd
Re: Two puddle tig
Postby Troy Boy 72 » Thu Apr 20, 2017 4:39 pm
Hey mate try a few more amps awhile adding a little filler and it will flow into the corner . Its all about that seat time and remember to be on the ball with it , cause depending on the thickness and what joint it is it will chew that corner off or blow a hole in it as quick as looking at it.
Cheers Troy
Troy Boy 72
Re: Two puddle tig
Postby Oscar » Thu Apr 20, 2017 5:12 pm
It is also in the very nature of the welding process. Using an electric arc emanating from a conical point, aimed at an inside corner joint, the walls of the joint are gonna be closer to the tungsten than the tip is to the root of the joint (this is especially true if you hold too long of an arc length-----hence why Jody is almost always saying in his videos "you need to hold a tight tight arc!). Electricity will therefore have a tendency to initially take the shortest path to ground, and there you have it: arc wander onto the walls and not into the root of the joint.
Some things can help with that:
  • bump up the current by at least 30-50%
  • reduce the cleaning action (not always possible because then you get contamination, but if you can, it will help a tad)
  • increase the AC Frequency
  • hold a tight arc! :D
Yes it is true sometimes you do simply need to add just a dab of filler to help bridge the gap, then get that puddle flowing into the root so you get good penetration.
HTP Invertig 221 DV w/ Arctic Chill cooler DV.
Millermatic 211 Inverter w/ Spoolmate-150
Eastwood Versacut 40A Plasma cutter
Oscar
Re: Two puddle tig
Postby Warrenh » Sun Apr 30, 2017 3:40 pm
Ditto on the small, very small, dav of filler to get the root started.
Warrenh
Re: Two puddle tig
Postby Otto Nobedder » Sun Apr 30, 2017 9:18 pm
Rather than rehash it, this Is being discussed in detail on another topic, here:
viewtopic.php?f=5&t=11602
Steve
Otto Nobedder
Re: Two puddle tig
Postby Oscar » Sun Apr 30, 2017 10:16 pm
Warrenh wrote:Ditto on the small, very small, dav of filler to get the root started.
The only thing I would add to that, is that IMO just adding a dab to bridge the two sides to "get the root started" is only part of it. Adding a bit more aluminum is gonna have it conduct more heat out of the root out to the sides that it actually bridges, unless you really mash the pedal even more to really punch it in now that the arc has a place to aim at, right above the root. Of course I'm just the one the hobbyists teach to, so it's just IMO. :lol:
Oscar
Re: Two puddle tig
Postby Warrenh » Mon May 01, 2017 9:27 am
I guess I should have added that you have to see the root melt in as you advance. If you can still see the corner you cant add filler.
Warrenh
