Cubitron-II sanding disks in a coarse. Everything you mentioned comes a distant second to them. To watch them obliterate metal makes it a pleasure to use actually.Chips O'Toole wrote:I hate metal prep. The flap wheel, knot wheel, and 72" belt grinder are slow. Today it occurred to me that my "needle scalers" might be called "scalers" for a good reason. Is this the tool I should be using?
- Chips O'Toole
Thanks for the reply.
There are about a trillion Cubitron products. Do you mean the flap disk or something for a DA sander?
The flap disks are good, but no I mean sanding discs that use a backer pad, although they are stiff enough that I sometimes don't use them with a backer pad for quick surface touch-up's, because you can get a really extreme angle on them. Also called fiber disks. They're like a round cut-out of "sandpaper", but they are damn stiff. I have some on my cheap ryobi grinder and will take pics when I get home.
- Farmwelding
I Believe oscar is referring to these
- image.jpeg (42.62 KiB) Viewed 811 times
- Chips O'Toole
Thanks.
Yesterday I got good results with a fiber paint-stripping disk. Like petrified Scotchbrite.
