It is currently Sat Jun 24, 2017 1:24 pm Advanced search
Torch for my Precision tig 185
Postby jroark » Sat May 06, 2017 10:26 pm
So I bought a precision tig 185 and it has a micro torch on it. I'd like to know if I can get a torch from CK for this machine and or would I do better to get one from somewhere else? It doesn't look like it has the Dinsen connector but I'll try to figure all that out after I get a new torch.
jroark
Re: Torch for my Precision tig 185
Postby jroark » Sat May 06, 2017 10:34 pm
My bad. I just looked at the machine and it does have the Twist-mate connector. Still wouldn't mind a few suggestions for a good torch. Also any info on a water cooler or if this machine is capable of that would be cool.
jroark
Postby LtBadd » Mon May 08, 2017 8:55 am
jroark wrote:My bad. I just looked at the machine and it does have the Twist-mate connector. Still wouldn't mind a few suggestions for a good torch. Also any info on a water cooler or if this machine is capable of that would be cool.
You'll need the water recirculator and the water cooled torch, the machine really doesn't come into play. Hard to go wrong with the CK 20 torch with flex cable
Insert witty, sarcastic, or philosophical remark here.
LtBadd
Postby hey_allen » Tue May 09, 2017 11:42 am
I bought a CK20 torch with the superflex cables, and was amazed at how much more flexible and unobtrusive the hoses are compared to the Chinese 26 torch that came with my machine.
The price isn't all that painful either, though definitely a bit higher than the Chinese stuff off of Ali or eBay...
-Josh
Greasy fingered tinkerer.
hey_allen
