Tig machine settings matrix?
Posted: Mon May 08, 2017 4:04 pm
by andreb
Has anyone ever seen a settings matrix for Tig welding that I can print and put on the side of my machine? On my Diversion its easy; one button, one dial, two modes. Not so clear on my old 330 A/B/P. I can probably do it myself but just wondering if anyone has ever seen one. I think the following would be helpful...
metal type - current - polarity - electrode type - electrode shape - material thickness - approx amps - shielding gas
You could also add in thing like: freg settings - pre/post timers - suitable filler types - etc.
If you weld everyday (which I don't ) I am sure you remember all this stuff. For us wannabe's it would be super helpful.
Re: Tig machine settings matrix?
Posted: Mon May 08, 2017 4:10 pm
by Farmwelding
Well... I dont have a chart off hand but selecting the additional parameters other than amperage, it probably won't work. Frequency is dependent on certain alloy and cleanliness of material, filler rod depends on alloy(s) and other factors,pre/post depend on size of cup among other things as well. And as for electrode type I would stay for the most part with one type of tungsten.
Posted: Mon May 08, 2017 4:23 pm
by dave powelson
andreb wrote:Has anyone ever seen a settings matrix for Tig welding that I can print and put on the side of my machine? On my Diversion its easy; one button, one dial, two modes. Not so clear on my old 330 A/B/P. I can probably do it myself but just wondering if anyone has ever seen one. I think the following would be helpful...
Best thing for you to do is keep running, loose leaf binder with notes of your own setups. I do and suspect others do as well.
Really helps to reference back, especially on joints/conditions that one may only deal with every 6 months or a year.
The 36 stored setup menus on my dyn. 350 help a bunch, but I still reference back to specific job deals to help get dialed in,
when needed.
Posted: Mon May 08, 2017 6:54 pm
by MarkL
They had these when I took welding in school. Looks like Miller still sells them. I think it has all the stuff you're asking for on it.
Posted: Mon May 08, 2017 10:06 pm
by Bobby Sixguns
I got a slide rule type of thing from Arc Zone with an order this past winter that is similar to what you're talking about. It list material types, thickness, recommended amperage settings, etc. They might be a good resource to check with.
Posted: Tue May 09, 2017 3:03 pm
by dave powelson
The milller, lincoln, etc. setup guidelines get one in the ball park,
then, more often than not, one adjusts machine parameters, torch distance/attitude, etc.
to get dialed in on a particular job......then one records this for then next time.
