It is currently Sat Feb 24, 2018 5:58 pm Advanced search
Everlast 160STH 3 prong to 4 prong dryer plug
Postby djrockytharp » Sun May 14, 2017 3:40 pm
I just got a everlast 160sth and wanted to be able to use the 220v dryer plug from time to time. The welder is a 3 prong and the dryer is a 4 prong dual voltage nema 14-30R. I've included pics of both plugs. How do I go from the 3 to the 4 without rewiring the welder. I'd still like to use the 110v adapter from time to time if I get side jobs. Would it be easier to find an adapter or just change the receptacle in the wall. Our Dryer runs off a separate 110 socket so the 220 is never used
djrockytharp
Re: Everlast 160STH 3 prong to 4 prong dryer plug
Postby nelson » Sun May 14, 2017 3:55 pm
I got a 12 GA short ext cord and cut off the female end. Got the right plug and just used that 110-220 adapter we got with the Everlast. I know it's Frankenwiring but it works fine. (nothing gets warm)
Also if anyone uses an extension for the standard 220 plug, just grease the thing. Man they can be hard to unplug. I wanted to stick a screwdriver in there :shock:
Also...don't use that bottom prong. It's the common so your dryer can get 110 volts for its controler or whatever. (maybe that's for the Bluetooth circuit :roll: )
nelson
Postby Otto Nobedder » Sun May 14, 2017 5:21 pm
nelson wrote:I got a 12 GA short ext cord and cut off the female end. Got the right plug and just used that 110-220 adapter we got with the Everlast. I know it's Frankenwiring but it works fine. (nothing gets warm)
The common and the ground are at the same potential, as they are bonded together at the main panel. You can use either for the center tap of the three-prong, as they'll be the same size wire all the way back to the breaker. Besides, your control circuits likely use the 110 in a DV machine.
Also, greasing the lugs on the plug is a good idea, but use an electric-rated substance, like N0-Ox-Ide A or something similar (and a little dab'll do ya). Hydrocarbon grease adds a layer of fire hazard in an overheated connection and/or if it builds up in the receptacle over time.
Two cents.
Steve
Otto Nobedder
Postby sedanman » Sun May 14, 2017 6:14 pm
Did you try to plug it in? If it fits, it'll work.
sedanman
Postby MarkL » Sun May 14, 2017 8:43 pm
djrockytharp wrote:How do I go from the 3 to the 4 without rewiring the welder.
It ain't cheap, but this is the kind of thing you need.
Lincoln Square Wave 200
Lincoln 225 AC/DC
Harris Oxy/Acetylene torch
MarkL
Postby Poland308 » Sun May 14, 2017 8:49 pm
Just get a male end and a female end and about 3 ft of wire. Even at HomeDepot you should be able to buy all you need for about 50$.
Postby Oscar » Sun May 14, 2017 9:53 pm
I hope you're not welding in the laundry room. :?:
HTP Invertig 221 DV w/ Arctic Chill cooler DV.
Millermatic 211 Inverter w/ Spoolmate-150
Eastwood Versacut 40A Plasma cutter
Oscar
Postby djrockytharp » Wed May 17, 2017 8:18 pm
Oscar wrote:I hope you're not welding in the laundry room. :?:
No. Our laundry room is connected to the garage. With two doors. One to the house one to the garage. So I can run an extension cord to that room and use the welder in the garage with the one to the garage mostly closed and the other door closed to the house.
djrockytharp
