http://tritool.com/product/model-304/
Use one of these if you don't have one already. Worth there weight in gold for SS tube.
I have one made by Lefon...awesome piece, basically face and weld.Poland308 wrote:http://tritool.com/product/model-304/
I did it for many years with a band saw, guide and a dedicated file...fit is everything.
Hey Rick wot's happenin?
Thankyou so much for your knowledge and experience, much appreciated!!!
I tried your setting 60amp, 2.5pps, 50% on time, 50% background current. I don't have a 1/16" gas lense for the fupa cup so I stayed with sharp 3/32" lanth. Result was incomplete penetration.
Increased peak current to 65amps, here is the result:
I think it's looking good, what do you think?
By the way, I am using band saw cuts for fitup, and dirty used for everything file. (I'll get a new one for really and truly welds)
- A9.jpg (75.05 KiB) Viewed 998 times
- A10.jpg (39.82 KiB) Viewed 998 times
Hey Rick,
by "devil's eye" I presume you mean the tiny keyhole at the leading edge of the weld pool. I also found I needed to keep the electrode at 90 degrees to keep control of the weld pool and penetration. Any lay back of the electrode immediately caused incomplete penetration.
Is this your experience?
