WildWestWelder
    Mon Apr 03, 2017 7:43 pm
A very well known veterinarian horse surgeon has asked me to extend a retractor for him. The material is very magnetic and by my research this could fall into the 410-416 series SS which is used for surgical tools of this type. Anything special about welding it and what type of rod?
Thanks
http://www.harrisproductsgroup.com/~/me ... ection.pdf
Looks like 309 would work. Or some 410. Might be a good project to use a purge box for
Kevin_Holbrook
    Wed Oct 15, 2014 1:02 am
could be 17-4 ph
WildWestWelder wrote:A very well known veterinarian horse surgeon has asked me to extend a retractor for him. The material is very magnetic and by my research this could fall into the 410-416 series SS which is used for surgical tools of this type. Anything special about welding it and what type of rod?
Thanks
The welds are simple enough. I'd use 312 or NiCrMo3 for a surgical tool. The suggestion of 410 can work, too, but as a Martensitic filler, some post weld heat treatment may be in order to keep the welds from being brittle.
What are you using to "extend" them? Do you have donor material from similar tools? Or are you stuck mixing materials?
Steve
