they arent meant to be perfect i weld fast very fast those aluminum pipes take about 3 min start to finish to weld...quality is perfect for the application and when you have to weld 100 of them..let me know how pulse works out for you
lets see your welds big guy!
I MUST BE READING THIS QUOTE WRONG.gurew wrote: pulse on aluminum is for hobby use haha a novelty....man up, set your amps for the material and full pedal it...perfect bead everytime here is a picture...
FIRST OF ALL, THE ORIGINAL POST MENTIONED PULSE BEING GOOD FOR ALUMINUM AND THE ANSWER FOR THAT IS YES. JUST BECAUSE YOU DONT USE PULSE IN THE TYPE OF ALUMINUM WELDING YOU DO DOESN'T MEAN THAT YOU TELL THAT PERSON THAT PULSE IS A WASTE OF TIME AND THAT IT IS FOR HOBBY USE. SECONDLY, WE CAN'T COMPARE WORK WITH EACH OTHER BECAUSE THE WORK THAT I DO IS FAR DIFFERENT THAN YOURS. I DON'T SIT IN A LITTLE WELDING CUBICLE ALL DAY AND PERFORM THE SAME WELD OVER AND OVER AGAIN A HUNDRED TIMES A DAY. JUST BECAUSE SOMEONE PRODUCES A PRETTY WELD DOESN'T MEAN THEY PRODUCE A PROPER WELD. DOING THE WORK THAT I DO, I CAN'T HAVE A BAD DAY,THROW THE PIECE IN THE SCRAP BIN AND START OVER.
- A 55 ft. DIAMETER DIGESTER LID FOR CITY OF YOUNGSTOWN WASTE WATER TREATMENT
- IMG_0178.jpg (70.26 KiB) Viewed 1396 times
- 24 in. INLET DIFFUSER FOR VAN PORT WASTE WATER TREATMENT
- IMG00192-20110210-1537.jpg (42.96 KiB) Viewed 1396 times
- A LIVE 48 in. WATER MAIN SADDLE FOR THE MAHONING VALLEY SANITATION DISTRICT
- IMG00127-20100903-0806.jpg (53.11 KiB) Viewed 1396 times
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
Hypertherm Powermax 85
Miller Digital Elite
JD2 Model 32 Bender
Oxy-Gas Torch outfit
Generac XP8000E Generator
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
kermdawg
- kermdawg
I aint gonna jump in the middle of this but I want to make a few comments-
Secondly, thats some bad ass shit your workin on Jpence. Kinda shit I wanna get into. One question-How do you weld on a live water line? All the hot taps I've done are with saddles and shut offs right on top that with take a right angle drill and drill through the pipe with a hole saw. You sprinkler fitters would know it as a T drill. But my last 6 years plumbing, I've done a lot of soldering and brazing, and if theres just a itsty bitsy bit of water in the line, your fucted. So how can that pipe possibly get hot enough to weld with all that water flowin through it and coolin it?
One of the first things I was taught when I started welding. I wish wish wish really wish they would put this on every welding machine that is sold. A truer statement has never been spoken. I argue with my brother who decided to weld his 30,000 pound (loaded) car hauler trailer frame after it busted with his 110 v flux core welder instead of his lincoln 225 ac welder. Pretty weld, but will it last? You'll definately hear about it if it fails. (hope to god it doesnt, thats my brothers livelihood)JUST BECAUSE SOMEONE PRODUCES A PRETTY WELD DOESN'T MEAN THEY PRODUCE A PROPER WELD.
Kermdawg,kermdawg wrote:So how can that pipe possibly get hot enough to weld with all that water flowin through it and coolin it?
That was the single most discussed issue with welding these mains. These are 80 year old mains coming directly out of Meander Reservoir and did not have a shut off between the resevoir and the water plant. Hence, the reason for the saddles. It was quite tricky, because where these mains were located, under high voltage power lines, they had pitted quite badly due to the anodic reaction (e.g., metal dissolution) which occurs where the current from the power lines returns to the original path, through the soil. Metal loss results at the anodic points, where the current leaves the structure. The wall thickness was about 3/8, but the pitting made it significantly thinner in spots. With 100psi of pressure of cold water behind the pipe wall it made it tricky. A fine balance of having enough voltage for proper penetration and not too much to end up with the pipe coming apart from too deep of an arc dig was the key. Believe me, when I was laying underneath that thing welding it, and my butthole puckered so tight I couldn't pass gas , all I could think about was if that was where I was gonna drown if that pipe come apart.
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
kermdawg
- kermdawg
So how did you guys cut in the saddles? Take some half round u bolts and bolt the saddle to the top, drill it and slap a shut off in? Cant see how that would work lol.Curious how you cut in a saddle that big on a live line.
Check out their website. Click on the toolbar where it says Hydra-stop
http://www.hydrastop.com/
If you want some real pics of the machine let me know and I'll post 'em.
Wait till you see how big the hole saw is they use to cut with. Obviously it's almost 4 ft. in diameter, but it really doesn't register in your mind till you actually see it.
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
kermdawg
- kermdawg
Wow. Thats exactly how we do hot taps on the smaller pipes alright. Big ol saddle clamp (we call em power seals) and just drill that hole saw through the valve, pop it back out and shut the valve off. I didnt think you could get a hole saw to drill through schedule 40 steel though. Specially bein so old and pitted, I would be worried about a crack developing. And with -no- shut offs on that line, thats insane man.
Id like to see some pics if you have the time
edit-Checked out all them hydra stop videos. Thats some cool shit man. I really like that insta-valve deal.
Pics aren't very good. Good thing I weld better than I take pictures. Barely
- Finished product. Water main is back-filled with and encased in concrete
- IMG00205-20110222-1127.jpg (42.34 KiB) Viewed 1358 times
- Coupon still in tapper machine
- IMG00211-20110222-1129.jpg (48.76 KiB) Viewed 1358 times
- Tapper Machine
- IMG00214-20110222-1130.jpg (47.44 KiB) Viewed 1358 times
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
Sarge
- Sarge
I guess that I "don't" weld production....hmmm. Maybe I should take another look at the website I posted and see what it is that I "Really" do? Maybe the units that we build here are done by hobbyists? Maybe the Lincoln Rep. that gives us our training is full of whoey? Or maybe someone has a pretty big ego? I try to learn something new everyday... am I learning yet?
Be Innovative.
Goal is perfection, but excellence is Acceptable.
Powermig 255C
Powermig 350MP x2
175 squarewave
Weld-pac 100
Hypertherm 600
Hypertherm 1250
Powermig 255C
Powermig 350MP x2
175 squarewave
Weld-pac 100
Hypertherm 600
Hypertherm 1250
Sarge,
I apologize if I offended you. My intention was to correct the bad information that pulse was a waste of time for aluminum welding.
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
Sarge
- Sarge
Not at all Jim. My reference was to the earlier post by the gurew saying that he welds production, not just a hobbyist. I used to be the night shift weld shop super for Arctic Cat, who oddly enough use pulse too...lol But I now do about 98% aluminum where I work as the fab mgr. But I too, am obviously full of hot air.
Be Innovative.
Powermig 255C
Powermig 350MP x2
175 squarewave
Weld-pac 100
Hypertherm 600
Hypertherm 1250
Powermig 255C
Powermig 350MP x2
175 squarewave
Weld-pac 100
Hypertherm 600
Hypertherm 1250
Can anyone here answer the title of this thread?
Pulse rate over 20?
Does this help with AC or DC?
Both?
I've done most of my TIG work with my Miller Dialarc HF and now I'm needing to replace it. Looking to buy a new machine and I have the same question as the OP.
Thanks
gunmaker
Pulse rate over 20?
Both?
Thanks
gunmaker
Sarge
- Sarge
AC for aluminum, obviously, yes. I would have to look back on my notes from earlier about DC but I want to say yes. I was using pulse MIG with the robots at Arctic Cat. I also use pulse MIG with the Linc MP350 also on aluminum. The Cobra push pull gun makes for a weld rivaling the TIG process, and guess what.....it makes for really FAST welding. (sorry...tongue in cheek shot there)
Be Innovative.
Powermig 255C
Powermig 350MP x2
175 squarewave
Weld-pac 100
Hypertherm 600
Hypertherm 1250
Powermig 255C
Powermig 350MP x2
175 squarewave
Weld-pac 100
Hypertherm 600
Hypertherm 1250
kermdawg
- kermdawg
It depends on what your welding-Material AND joint design. Even if your not currently in need of it, you might in the future, and springing the extra money for it now can save you from having to buy another machine later.
Someone posted on here awhile back, when it comes to welding machines(and damn near anything else thats expensive in life)-Those who are cheapest end up payin more in the long run.
Buy the most machine you can decently afford, and you wont regret it.
