Yes - stop buying those retarded flow meter things that are set to insane pressures - get a decent adjustable regulator ( a twin stage oxy gauge works really well - if it bothers you you can swap the little pressure gauges over to some that say argon ) - put a floating ball on the output - adjust it to the minimum pressure needed to achieve fractionally more flow than you use - fine trim the actual flow with the needle valve - no more big surge ! there are dedicated regulators designed to achieve consistent flow without surge but they are kinda pricey for hobby use.
Thanks all! I'm gonna fix this for sure. I did a tiny fix job an noticed the surge was messing with the arc. That said, I have 20 feet of 1/4 od tube to the microwelder, and 6 feet of 1/4 I'd to the Everlast....all downstream of the flowmeter. Not good.
In addition I found that even using the pedal, the downslope knob has an effect. Also not good! I have to remember to set it to zero.
taiwanluthiers
- taiwanluthiers
I got the same problem. Huge rush of gas when you press the trigger. You're wasting gas, but not only that the rush of gas actually blows the damn arc around, causing the tungsten to burn and getting crap welds.nelson wrote: ↑Fri Jun 23, 2017 11:34 pm HI folks.
I have the welder listed below. It came with a flowmeter. I was wondering if the pressure is too high though.
When I start a weld there's a big gush. I don't know if it's adjustable. I could put a regulator ahead of the flowmeter I guess. I don't know if this affects my Al but my steel looks fine.
I use the same tank for a microwelder. Big gush thru a little nozzle.
I found a sticker covering the head of the regulator, and found a set screw. Turning that set screw counterclockwise lowered the pressure. I'm not sure how much (there is no gauge telling you this) but my welder's manufacturer (Andeli) recommends setting the pressure to about 2 bars or so, or 30 psi. This would save gas, and then to set the flow rate (if using a cup) to about 3 liters per minute. You'd use barely any gas if you do this.
Jack Ryan
- Jack Ryan
You can do that, but the flow meter would no longer be calibrated. In the and, that is not critical as you generally use "enough shielding", not a particular flow. It makes a difference to those following a procedure or wanting to share settings.taiwanluthiers wrote: ↑Wed Dec 13, 2023 11:43 amI got the same problem. Huge rush of gas when you press the trigger. You're wasting gas, but not only that the rush of gas actually blows the damn arc around, causing the tungsten to burn and getting crap welds.nelson wrote: ↑Fri Jun 23, 2017 11:34 pm HI folks.
Jack
This entire years old thread is a solution in search of a problem. A single, moment of a rush of argon is completely inconsequential to welding. Anyone who doesn’t tap a pedal when first setting up, or checking for leaks after a tank swap is an alien. You can’t even begin to calculate the “lost cost” of argon for that momentary rush of gas.
Jack Ryan
- Jack Ryan
It matters to some, for example if there are several welders doing spot welding. The surge happens at every trigger pull, not just at setup.cj737 wrote: ↑Wed Dec 13, 2023 7:42 pm This entire years old thread is a solution in search of a problem. A single, moment of a rush of argon is completely inconsequential to welding. Anyone who doesn’t tap a pedal when first setting up, or checking for leaks after a tank swap is an alien. You can’t even begin to calculate the “lost cost” of argon for that momentary rush of gas.
It is quite easy to calculate the loss of gas and it can approach the gas used during preflow so you get double preflow gas dumped every trigger pull. I am happy you and I are unaffected, but others are and calling them aliens doesn't make it less so.
Jack
for me gas is expensive. so i usually try anything but its never really bothered me. i doubt its much usage. someone did work it out and i believe its sweet stuff all for general welding.cj737 wrote: ↑Wed Dec 13, 2023 7:42 pm This entire years old thread is a solution in search of a problem. A single, moment of a rush of argon is completely inconsequential to welding. Anyone who doesn’t tap a pedal when first setting up, or checking for leaks after a tank swap is an alien. You can’t even begin to calculate the “lost cost” of argon for that momentary rush of gas.
if i remember right there is special regulators (2stage?) to stop that gush of argon. but you might be spending more on parts that what you save.
with tack welding, the after flow will matter more. so i try to do the tacks fairly quickly so you do the next tack before the gas even stops.
i think the original question was with a possibly faulty regulator (or cheap one) that was set to high to start with.
one problem with lowering the pressure of the regulator, the flow meter will be inaccurate. might pay to use a torch end flow meter to set it.
also don't lower it so much you run into coverage problems. cheap regulators can have quite a lot of difference between set pressure and run pressure.
taiwanluthiers
- taiwanluthiers
I had a problem with the big gush of argon. Not only am I wasting gas that gush actually causes turbulence which isn't good.
I found a way to adjust my regulator. It's normally taped with a label but once undone there's a set screw that adjusts the output pressure.
My welder manufacturer actually recommends 15 psi for gas. It saves gas and eliminates turbulence.
Or a limiter in line works too, but personally I think 70 psi is too high.
