rahtreelimbs
    Mon Jun 14, 2010 10:39 pm
When do use 4043 or 5356?
    Sat Mar 30, 2013 11:49 am
    Sweden
Google "alcotec filler alloy chart"
Helps pick filler wire based on what alloy you are welding.
Other rules of thumb when not critical:
4043 for casting , high silicon amount
Not 4043 if you will anodize, weld will discolor.
5356 for most other things specially marine stuff.
Very simplified but as said the chart will be a better guide
m0mri
    Thu Jul 06, 2017 4:38 pm
This may not assist in your choice but I was quite interested in all the various types of fillers so prepared a spreadsheet scheduling many of the more common fillers to include their composition.
When I started, I also wanted to know how many rods one could buy per kilo so I extrapolated from the composition to approximate the number of rods. That then expanded into calculating cost on a pre rod basis. Here is the spreadsheet in case it should be of any use https://cloud.titmus.org/index.php/s/ucZ8eSjTcNLBrVC
I have put some comments in that I had drawn from various sites and forums so if anybody should like credit or would like me to make any amendments, please do let me know.
Andrew
Holy shit that's a nice spread sheet! I need more time than I have to read it. I'm going to be a while.
    Thu Mar 10, 2016 11:37 pm
    Wisconsin
There is also a blue demon filler metal app that you can select your base materials and it tells you what to use.
