idflyit
    Tue Jul 04, 2017 4:34 pm
im trying to tig weld 3/8 Aluminum ...please help me set this up...once I have a puddle formed,when filler rod is added it balls up as goes away from the puddle....ahhhhh OMG thx to all in advance
Torch angle is too flat or your arc length is too long. With aluminum, you need to stuff the wire in quickly to prevent "burn back" of the filler before it reaches the puddle. Torch angle as close to 90* as you can get it please-
Mike
    Mon Dec 06, 2010 1:09 pm
    Andover, Ohio
Welcome to the forum.
M J Mauer Andover, Ohio
Linoln A/C 225
Everlast PA 200
idflyit
how do I shorten the arc thx again
nelson
    Sun Jul 17, 2016 1:21 pm
    near philly
That's where practice helps. You have to just get that tip very close. Tho 90 degree thing concentrates the gas and stabilizes the arc. Jody's vids show how he backs the tip off a bit when dabbing.....not so much away from the part, but backing up along the weld line.
idflyit
OK thank you where can I find Jodis Vids
idflyit
I found Jodis vids on YouTube thank you so much
