It is currently Fri Feb 23, 2018 1:53 pm Advanced search
Can't decide which welder to get ? [210 DX vs 280 DX]
Postby redonion » Sat Jul 15, 2017 2:33 pm
I am a beginner with under 1 hour torch time who is looking to learn TIG welding for in-house prototype production so I am not looking to be a all around welder.
Machine will be used for aftermarket automotive parts such as;
Exhaust manifolds
Intercooler Piping
Cooler Fabrication [intercooler/coolant/oil etc..]
Overflow-Expansion tank fabrication
Local Miller dealer sold all of their Dynasty DX 210-280s but I got the Coolmate 1.3 and the RFCS-14HD wired foot control and I want to reserve a machine in the next shipment so I need to decide which machine I will get.
Salesperson thought that they had a 280 DX on display and gave me a much better discount on that unit but apparently they even sold the display unit but dealer will honor their pricing on 280 DX because he supposed to spare a 210 DX for me.
My concern is, does 210 DX and 280 DX will perform same on low amperage welds ? I am asking this because on Miller's web site 210 DX is rated for 0.002 in. (0.05 mm) steel welds and 280 DX is rated for 0.004 in. (0.1 mm) steel welds. Does they have the same arc performance/quality ? Long story short, does 210 DX have any advantages over 280 DX ? or are they practically same machines with different amperage rating ?
I have also ordered a CK Flex-Loc FL230 water cooled torch with adapter and 3M 9100XXi welding helmet.
Thanks
redonion
Re: Can't decide which welder to get ? [210 DX vs 280 DX]
Postby cj737 » Mon Jul 17, 2017 9:02 am
They are essentially the same machine with the upper amperage capabilities, but the 280 does NOT run on 120v where the 210 can. Both will run 1- or 3- phase.
My decision would be based upon the need to weld thick aluminum. If you will regularly weld 1/4" or thicker ally, the 280 would be highly recommended. The 210 will do it, but it will be at full capacity to do so. Either new machines will have the variable wave forms and frequency settings, both should have 1 amp arc start too.
The 210 has a $500 rebate right now, but I'd still opt for the 280 if you can afford it. These guys usually have the best prices on equipment, and are very good to deal with for Customer Service and Support: www.weldingsuppliesfromioc.com
https://www.weldingsuppliesfromioc.com/ ... der-907551
You only need to buy the power supply since you have work leads and a remote pedal.
Postby Oscar » Mon Jul 17, 2017 9:28 am
1A DC/2A on AC for the 280s. Purty darn good. :)
HTP Invertig 221 DV w/ Arctic Chill cooler DV.
Millermatic 211 Inverter w/ Spoolmate-150
Eastwood Versacut 40A Plasma cutter
Oscar
Postby Skylineauto » Mon Jul 17, 2017 2:52 pm
You are going to be doing the same type of work I do at my shop. Because of that the 210 DX will be enough machine for your work. The lowest amp setting I have ever needed was 25 amps for some thin titanium. When going intercoolers Im not more than 175 amps. With the Dynasties the beauty is using the balance and frequency to achieve better penetration with aluminum.
Skylineauto
Postby zank » Tue Jul 18, 2017 8:59 am
I like the headroom that the 280 offers on the top end for aluminum. The low end is great and you can really soften the starts if you need to for the thin stuff.
Mike Zanconato
Zanconato Custom Cycles
@mzank on Instagram
Dynasty 280DX
Meco Midget
zank
