It is currently Fri Dec 15, 2017 4:22 am Advanced search
Foot pedal w/ Everlast 160STH
Re: Foot pedal w/ Everlast 160STH
Postby dgapilot » Wed Aug 09, 2017 8:17 am
Any chance it's just the way the pedal is wired? Do you live close to someone with another Everlast machine that you could try an Everlast pedal to see if it behaves the same?
David
Everlast 210 EXT
Lincoln AC225
Lotos LTP5000D
Oxy-Acetylene
dgapilot
Postby DrivenToMake » Wed Aug 09, 2017 3:15 pm
dgapilot wrote:Any chance it's just the way the pedal is wired? Do you live close to someone with another Everlast machine that you could try an Everlast pedal to see if it behaves the same?
No chance it's the pedal. There are 3 circuits at work in the pedal. 7 Contacts. Contacts 6 & 7 are shorted. That tells the welder there is a pedal plugged in. 3/4/5 are connected to the potentiometer, which controls the amperage through the pedal's range of motion. 1/2 are the momentary, which lights off the HF start, argon and arc.
As a sanity check, I ran the pedal through it's paces on a meter and a scope.
Pedal is wired correctly and works as intended.
Sent from my SM-G925V using Tapatalk
DrivenToMake
Postby DrivenToMake » Wed Aug 09, 2017 3:29 pm
nelson wrote:DTM, let us know if the return goes smoothly.
I have a 164si and been lucky I guess. Just curious, when you're welding it bounces from 11 to 12, but when you release pedal completely it reads correct?
Home Depot will take it back, no problem. It's the main reason that I ordered it through them.
No, pedal plugged in, not welding, the display bounces back and forth between 11 and 12. No matter where you set the amperage.
Once you start welding, it does display the amperage based on where you have the pedal in its range of motion. I only know this because I lit it off on a piece of scrap so that I could see what the display was doing during welding.
I agree that you could easily set the welder to a particular amperage and leave it there while you're welding the same thickness of material, same fit-ups.
But practicing on a wide variety of set ups and material thicknesses makes amperage adjustments a pain.
DrivenToMake
Postby dgapilot » Wed Aug 09, 2017 3:33 pm
That would be a pain to have to unplug the pedal to adjust amperage, then plug it back in. I've seen Jody use a 160STH in some of his videos, but never looked at the display when he wasn't welding.
David
Everlast 210 EXT
Lincoln AC225
Lotos LTP5000D
Oxy-Acetylene
dgapilot
Postby DrivenToMake » Wed Aug 09, 2017 3:34 pm
nelson wrote:If he's saying the readout only indicates the amperage when the pedal is not plugged in, that's lame. Id probably send it back too.
But if it's goofy when the pedal is pressed only, I for one can't tell you what it reads while I'm welding. I'm watching the puddle. In that case I'd keep it.
Monday I'll see how mine works.
Right, if that's what it was doing I couldn't care less.
I know a lot more experienced welders can set their welder to max amperage and control everything on any thickness of material, but I can't do that. I want to set the amperage 20%~ above what I'm going to need so that I can quickly puddle and ease off.
DrivenToMake
Postby LtBadd » Wed Aug 09, 2017 7:43 pm
DrivenToMake wrote:I know a lot more experienced welders can set their welder to max amperage and control everything on any thickness of material, but I can't do that.
Even so this is anything but an ideal situation, if I needed to make a weld at 30 amps no way I'd set my machine to 210 amps
Insert witty, sarcastic, or philosophical remark here.
LtBadd
Postby nelson » Wed Aug 09, 2017 8:06 pm
The only stake I have in Everlast is my unit with 1 year and no probs.
Quite disconcerting. I guess your unit didn't come with a pedal? 160 is a lot for 2 stampings, a spring, a pot, switch and a cord.
The strain relief on mine came loose so I know how to open it up....it's just pried open, not screwed. Kinda low end.
What'd your welder cost? I love being able to do aluminum in my work.
nelson
Postby dgapilot » Thu Aug 10, 2017 12:23 am
When I got my 210 EXT a couple weeks ago, I got the Nova foot pedal upgrade with 25' chord. They only charged $100 for the upgrade. Goth the 25' cables for both torches, and a CK flex head 9, and I think that was only a $10 upgrade. Kind of hard to see how the pedal cost that much.
David
Everlast 210 EXT
Lincoln AC225
Lotos LTP5000D
Oxy-Acetylene
dgapilot
Postby DrivenToMake » Thu Aug 10, 2017 2:15 pm
nelson wrote:The only stake I have in Everlast is my unit with 1 year and no probs.
No, it didn't come with a pedal. Ironically, they used to offer the pedal as part of the package. I had been researching what TIG welder to buy for quite some time and settled on this one because of my impression that it was going to come with a pedal. My fault, but I didn't verify that it still came with a foot pedal as part of the package. I was a little bit surprised when it arrived and it did not have one. So when looking for a foot pedal, SSC controls was universally recommended. If you think they're expensive, you should see what a Miller pedal costs.
dgapilot wrote:When I got my 210 EXT a couple weeks ago, I got the Nova foot pedal upgrade with 25' chord. They only charged $100 for the upgrade. Goth the 25' cables for both torches, and a CK flex head 9, and I think that was only a $10 upgrade. Kind of hard to see how the pedal cost that much.
I looked into making my own, but the components were coming to a cost that didn't make it worth my time. I guess it really depends on what they are using inside. According to SSC, they're using a precision potentiometer. If I go to Mouser, a 2-watt precision potentiometer is in the $40 range. Momentary is like $10-15. Cable only comes in like 400 foot spools, so I have to go to a different company for that and that would be around $30 with shipping. Connector is like $10 shipped. Then I have to fab a pedal, or try to salvage a pedal from something else.
In the end I decided I just want to get welding.
DrivenToMake
Postby DrivenToMake » Fri Aug 11, 2017 4:20 pm
Apparently, I ticked off some Everlast representative in their forums by posting this issue there.
What a rambling jack-hole response...
He says this is the design of the machine. It's reading where the starting amperage will be 11-12, based on the potentiometer position. And that the display updates actual amperage as you depress the pedal. You set the amperage based on the relative position of the knob.
Fair enough, but that's not what the tech support guy told me.
Not winning any friends that guy...
DrivenToMake
PreviousNext
